My SAS introduction (LOT OF PICTURES) #920070 12/11/08 03:58 AM
UPRaider Offline OP
Hey guys,
Tag asked me to post up some pictures of my recent solid axle swap i did on my 89 2.6L Raider. I live in the UP of Michigan in a town called Calumet. I am a mechanical engineering student at Michigan Tech University and work part time at Ace Hardware. I am a member of MTU's (mich tech) 4wheelers club and love being outside.
Anyway to the SAS (sorry for the large blurry pics)
Here is a "stock" photo, or how it looked when I got it. I bought this 89 for $200.
Up on "Cliff Drive"
The donor axle. Dana 30 from an 02 Jeep TJ
After torching the IFS. Lost some weight.
Extra weight
Front spring/ shackle cross member
springs mocked up
Setting caster/pinion angle
Front spring hanger (has since been gusseted more)
5/8" spring plates
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN0976.jpg[/img]
Spring perch
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN0985.jpg[/img]
Rear shackle mount
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1010.jpg[/img]
Rear - Spring over with YJ leaf springs
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1016.jpg[/img]
Knuckles from a 2002 jeep grand cherokee (WJ)
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1022.jpg[/img]
This shows the hub spacer I had to make
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1024.jpg[/img]
WJ caliper bracket
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1025.jpg[/img]
Dana 30...switching gears-3.73 to 4.56
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1074.jpg[/img]
Had to cut the carrier bearings off
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1083.jpg[/img]
First set up
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1087.jpg[/img]
The roof rack I made
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1097.jpg[/img]
New WJ knuckles on TJ's dana 30
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1098.jpg[/img]
New front bumper
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1114.jpg[/img]
This adapter got me from the raiders front drive shaft to the dana 30's 1310 u-joint yolk
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1125.jpg[/img]
One ton tie rod ends
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1126.jpg[/img]
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1132.jpg[/img]
Front and rear "done"
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1135.jpg[/img]
Sits level
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1140.jpg[/img]
DOM for 1-ton steering (high steer) over the knuckle
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1151.jpg[/img]
Making the front drive shaft work
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1146.jpg[/img]
Sleeved with DOM
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1149.jpg[/img]
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1150.jpg[/img]
Tacking adapter
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1156.jpg[/img]
Welded
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1159.jpg[/img]
Mocked up "poop pipe" steering
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1168.jpg[/img]
Front ds angle
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1173.jpg[/img]
OBA tank and rear sus.
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1179.jpg[/img]
New interior panels (old ones were missing)
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1185.jpg[/img]
Flexible brake hoses from 02 Jeep TJ
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1189.jpg[/img]
Waiting for more gas
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1194.jpg[/img]
Flex testing
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1198.jpg[/img]
Next to dads F350
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1199.jpg[/img]
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1200.jpg[/img]
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1201.jpg[/img]
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1202.jpg[/img]
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1203.jpg[/img]
On the trailer
[img]http://i159.photobucket.com/albums/t132/ryanszpara/4x4wire/DSCN1210.jpg[/img]
I have more pics if you need. I have since doubled the spring packs as they flattened way out. I dont have shocks on it yet, those will come soon. I also just built an anti-wrap bar for the rear. The truck is stock except for what you see. Stock engine, trans, t-case, rear axle ect.
THanks guys!!!
Ryan
1989 Dodge Raider 2.6L
SAS with 33x12.50 MTR's
Re: My SAS introduction (LOT OF PICTURES) [Re: UPRaider] #920071 12/11/08 04:52 AM
stony-man Offline
Glad you posted!
What's that I spy sitting on the front of the trailer? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: My SAS introduction (LOT OF PICTURES) [Re: stony-man] #920072 12/11/08 05:09 AM
cool truck but why dana 30? is it just temporary? I think the weight of the montero would be to much for the little guy.
Re: My SAS introduction (LOT OF PICTURES) [Re: UPRaider] #920073 12/11/08 06:12 AM
ghostraider Offline
Your Welds look Awesome. That is some Fine Work and i am sooooo jealous.
but in a Respectful way.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: My SAS introduction (LOT OF PICTURES) [Re: UPRaider] #920074 12/11/08 06:22 AM
cap510 Offline
Welcome to the wire! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Looking good! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: My SAS introduction (LOT OF PICTURES) [Re: cap510] #920075 12/11/08 07:53 AM
LandRaider Offline
Swap looks great, but you're gonna HATE HATE HATE HATE that D30.
It's seriously crap.
Re: My SAS introduction (LOT OF PICTURES) [Re: LandRaider] #920076 12/11/08 12:21 PM
Mad_Scientist Offline
Welcome! Nice work. I really like your roof rack. Do you have any pics showing the gutter mounts? Did you make those too?
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: My SAS introduction (LOT OF PICTURES) [Re: Mad_Scientist] #920077 12/11/08 04:23 PM
Angelo Offline
Good work, glad to see you found it for $200 and already built it up <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Whats next on the list, gettin rid of some of that rust? <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: My SAS introduction (LOT OF PICTURES) [Re: TOASTY] #920078 12/11/08 11:35 PM
UPRaider Offline OP
CRF 250F!!
Re: My SAS introduction (LOT OF PICTURES) [Re: TOASTY] #920079 12/11/08 11:37 PM
UPRaider Offline OP
The Raider actually weighs less than a Jeep, but yeah its temporary. I had the D30 so I used it. I plan to upgrade to a D44 or maybe bigger.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6557 MB (Peak: 0.8100 MB) Data Comp: Off Server Time: 2026-06-21 00:12:05 UTC
