Low Power:Exhaust Leak Upstream of O2 Sensor #920093 12/11/08 05:33 AM
matts Offline OP
My recently purchased '89 4runner 3.0 V6 starts and idles well, but has less power than my 22RE truck and runs a little rough under throttle. I haven't really had time to do any troubleshooting yet, but I noticed the the exhaust pipe has a fairly big leak in it just upstream from the O2 sensor. Any ideas on how likely that is to cause the motor to run like this? No check engine light yet.
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Low Power:Exhaust Leak Upstream of O2 Sensor [Re: matts] #920094 12/12/08 08:59 AM
Snowtoy Offline
I would think it would take more than a large leak. I had a similar loss of power about 7yrs ago, but the connector at the cat came loose, and the two ends separated about an 1".
Re: Low Power:Exhaust Leak Upstream of O2 Sensor [Re: Snowtoy] #920095 12/12/08 03:28 PM
A
Anthony_89 Offline
try covering the hole with something and running it.. see if it helps...
Re: Low Power:Exhaust Leak Upstream of O2 Sensor [Re: matts] #920096 12/13/08 10:35 AM
Davepet Offline
The o2 sensor is vital & if it isn't seeing the correct exhaust gas mixture, it can definitely affect how your engine runs.
The leak needs to be fixed in any event, so might as well do it & see if it helps.
Dave
Re: Low Power:Exhaust Leak Upstream of O2 Sensor [Re: Davepet] #920097 12/15/08 12:47 AM
matts Offline OP
That was my worry, that the O2 sensor is getting bad signals. Fortunately this is a project vehicle and not my daily driver. It's winter here and I have no heat in my shop yet, so I will be glad to start on this project again in April.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6036 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-07-09 14:54:50 UTC
