wheel ideas #920158 12/11/08 11:47 PM
k120189 Offline OP
ok so i've been collecting wheels left and right but closest thing i can get to a full set of wheels is three. so i have 5 similar wheels but two have more offset...so this is more of an opinion i can run two different offsets. but would u put higher offest rims in front or back...in my mind the front would give it that baja look while the rear would give it almost a dragster look
more offset up front or in the rear
single choice
Votes accepted starting: 12/11/08 10:46 PM
You must vote before you can view the results of this poll.
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: wheel ideas [Re: k120189] #920159 12/12/08 12:26 AM
DEFBOY35 Offline
i say get a set of wheels that has the same offset
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: wheel ideas [Re: DEFBOY35] #920160 12/12/08 01:31 AM
k120189 Offline OP
i can but i kinda think more offset in front would look kinda cool its only about an inch difference
Re: wheel ideas [Re: k120189] #920161 12/12/08 02:19 AM
jaboo5322 Offline
Front offset would give it that truck puller look. They offset the front to take advantage of more fresh track surface. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: wheel ideas [Re: jaboo5322] #920162 12/12/08 04:35 AM
DEFBOY35 Offline
keep in mind, maybe this is only my truck, but even with the same offset, my fronts still stuck out a little past the rears as it was. im not sure if the rear wms to wms is slightly shorter than the front or not, and i dont feel like searching for the answer at the moment.
Re: wheel ideas [Re: DEFBOY35] #920163 12/13/08 06:36 AM
dirtcrazy Offline
Yes, same here. Most likely due to the difference between the IFS and the live axle suspension designs.
Got torque?
'02 Ford F-350 STD Cab V10 6sp 4x4
12MPG in town and 15-17 on the highway.
Re: wheel ideas [Re: dirtcrazy] #920164 12/13/08 11:23 PM
rcounts Offline
So if the rear axle is slightly narrower track than the front, and you put the wheels with more offset (less backspacing) on the rear axle, you should end up with both the front and rear having pretty close to the same track width, right?
That's the way I'd go with it...
Re: wheel ideas [Re: rcounts] #920165 12/14/08 02:02 AM
jaboo5322 Offline
I can definately tell the front tires stick out a little more than the rear. If you have a lift you can see the difference alot more when the tire moves up and down in the front. The setup has to move in and out due to the a arms.
1989 Dodge W250.
Re: wheel ideas [Re: jaboo5322] #920166 12/14/08 02:11 AM
k120189 Offline OP
im gonna try both and see how it goes...wont be able to get my spacers till the new year so...we'll wait and see
Re: wheel ideas [Re: k120189] #920167 12/14/08 10:42 AM
DEFBOY35 Offline
another thing to take into consideration is rotating your tires.
PHP: 7.4.33 Page Time: 0.009s Queries: 19 (0.006s) Memory: 0.6558 MB (Peak: 0.8210 MB) Data Comp: Off Server Time: 2026-06-10 07:22:36 UTC
