WANTED: 6G72 3.0L Water Pipe for '93 LWB Gen2 #920359 12/13/08 06:28 PM
Bijol Offline OP
My '93 Gen2's water pipe broke. It's the coolant tube that connects to the water pump and runs the length of the block through the middle.
I've searched all the local yards, and found NOTHING.
Any good used ones out there?
Re: WANTED: 6G72 3.0L Water Pipe for '93 LWB Gen2 [Re: Bijol] #920360 12/15/08 02:28 AM
kewlynx Offline
Might also cast a little broader at www.car-part.com Good luck!
**ubi apis- ibi salus**
Re: WANTED: 6G72 3.0L Water Pipe for '93 LWB Gen2 [Re: kewlynx] #920361 12/16/08 07:30 PM
Any difference between a 1991 3.0L and yours??
Re: WANTED: 6G72 3.0L Water Pipe for '93 LWB Gen2 [Re: rxinhed] #920362 12/16/08 08:36 PM
Bijol Offline OP
None that I know of...it's basically the same 3.0L 6G72 engine. The electronics change, like the ECU and ignition, but the mechanical parts are almost identical.
I've checked several water tubes online, and they don't seem any different regarding size and the angle of the two outlets on the rear.
I found one used for $25 which is pretty good, and one new for $53. I'm probably going for the new one, just to make sure that I NEVER have to replace this again.
Re: WANTED: 6G72 3.0L Water Pipe for '93 LWB Gen2 [Re: Bijol] #920363 12/16/08 10:18 PM
Okay!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6054 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-06-21 18:59:24 UTC
