my monty died on the interstate
#920532
12/14/08 11:24 AM
i was driving on i79 in morgantown wv about 100 miles from home and all of a sudden she quit. there was no jerking or sputtering she just shut off, after sitting on the side of the road for 5 hours in 18* weather and nobody stopping to see if i was ok even though i had my flashers on and wrote help on the back of my monty. well finally my cousin came and said the fuel pump didnt sound like it was getting power or was bad so we replaced it.
after replacing it it still wouldnt start and when we checked for spark from the coil there was none.
besides replacing the coil what else should i check?
Re: my monty died on the interstate
[Re: 91monterov6]
#920533
12/14/08 11:32 AM
My Raider did the SAME THING. Check your ECU, I found that my windshield leaked onto the ECU causing the connections to become too corroded. If you have a spare swap them out.
Check there first and report back.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#920534
12/14/08 11:51 AM
ive been trying to find a spare ecu, but ive always been broke lol, guess ill have to buy one.
[Re: 91monterov6]
#920535
12/14/08 02:25 PM
anyone got a working ecu i can borrow to test with? ill ship back when done
[Re: 91monterov6]
#920536
12/14/08 02:42 PM
[Re: sasnydley]
#920537
12/14/08 03:17 PM
would the tbelt breaking cause no spark at the coil?
[Re: 91monterov6]
#920538
12/14/08 03:48 PM
That stupid little black box next to the coil will stop spark. There is also a sensor in the dizzy that will stop spark. Did you try the fuel pump tester plug to power it, or just turn the key? I dont think it runs if you just turn the key. If it is a broken timing belt, it will sound weird when spinning just the bottom of the engine over. The ECU will also just die with no warning. It should give you a check engine code though. Did you check those?
[Re: sparkem]
#920539
12/14/08 05:07 PM
we tested the pump while cranking, what is the lil black sob by the coil called incase i hava to go to AZ or napa
[Re: 91monterov6]
#920540
12/14/08 09:52 PM
NAPA P/N TP125 Ignition Control Module.
You need to take out the ECU first and smell for nasty fish, which means mushroomed caps. That's the first place to start...
[Re: hazy_daze]
#920541
12/14/08 10:50 PM
ecu is clean, immaculate, lookslike new
