TJ center ConSole SUbwoofer #920566 12/14/08 02:15 PM
rub1out Offline OP
I just changed the head unit on my TJ and now my subwoofer doesn't work. Some one told me you could bypass some wire to hook it back up but which one do i do. ANy one had any problems with this before. I don't want to do after market speaker just get my Stock one back and running....
2004 Rubicon, 35x12.50 Kumho ventures, 8" of lift, Custom Roll Cage, 9500 warn wench, edge upper with computer.
Re: TJ center ConSole SUbwoofer [Re: rub1out] #920567 12/14/08 04:54 PM
Brown81CJ5 Offline
I don't think the TJs came with subwoofers from the factory. So that would mean that your speaker is already an aftermarket one.
Is your sub hooked up through an amp via an RCA cable from the head unit?
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: TJ center ConSole SUbwoofer [Re: Brown81CJ5] #920568 12/15/08 09:53 PM
playinmud Offline
i think the later model tjs came with subwoofers. you should trying emailing the tech group at crutchfield.com
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5936 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-10-24 08:16:01 UTC
