Page 1 of 3 1 2 3
Pre 3.4 Swap Questions #921527 12/20/08 02:38 AM
yotaman7 Offline OP
I've been researchin the heck out of this swap for awhile. I have a good 3.4 long block but no ecu and harness. I keep searchin craigslist, ebay, and local salvage yards but can't seem to find the other parts I need. From reading the posts on this swap I've realized that it is important to get all of your parts from one vehicle to avoid a potential p.i.t.a. Let me know if any of you know of any donor vehicles for me.
Anyways, my main question that I could not seem to find an answer for is can I use the manual trans and t-case from an 01 tacoma in my '85? Is it a different length from my stock '85 trans and t-case?
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Pre 3.4 Swap Questions [Re: yotaman7] #921528 12/20/08 04:38 AM
ScaldedDog Offline
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
Re: Pre 3.4 Swap Questions [Re: ScaldedDog] #921529 12/20/08 06:05 AM
yotaman7 Offline OP
Thanks mark, you helped me find my answer. I've been to ORS web site plenty of times before but have never found their faq till I just stumbled upon it after using your link. Here is the answer to what trans and t-cases you can use for this swap.
Thanks again!
'93 pickup 2WD
'85 pickup 4WD
Re: Pre 3.4 Swap Questions [Re: yotaman7] #921530 12/20/08 06:52 AM
G
Greg_Canada Offline
ORS is no longer making harness'. I know this because i ordered the last swap kit on tuesday. They are closing up shop for an undetermined amount of time. Mike said they may re-open in the new year but he doesn't know what parts they will make, he said to check the site.
You can use the tranny but you need the transfer case from an 88-95 v6 5spd. (or a marlin adaptor).
And yes, you should get the harness with the engine, because they used different ones. What year is your engine? Many years do not have interchangeable sensors...
89 4Runner
Re: Pre 3.4 Swap Questions [Re: Greg_Canada] #921531 12/20/08 06:43 PM
ldivinag Offline
doggone it...
ORS is the only one that makes the 3.4 convert harness?????
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Pre 3.4 Swap Questions [Re: ldivinag] #921532 12/22/08 03:04 AM
kewlynx Offline
As far as we know, yes. We've had quite a few guys here just go ahead and download the EWD's they needed and configured their own harnesses, so it's not impossible.
**ubi apis- ibi salus**
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921533 12/22/08 05:02 PM
CJM Offline
i'm building my own .. using the original wiring from the donar .. EWD's for both trucks , and some patience .
83 Trekker SR5
NEW Trekker forum
Re: Pre 3.4 Swap Questions [Re: Greg_Canada] #921534 12/23/08 05:23 AM
yotaman7 Offline OP
The engine I have is from a 00 taco. However, I do not have the intake, etc. for this year. So when I find my donor I will steal all of the intake/fuel injection components also.
I hope I can find something soon, the old 22re is soundin' pretty sad with it being so cold out.
Also, since ORS will no longer make the harness, at least for now, it looks like I get to have some fun and make my own! Oh well, gives you more pride when you done it yourself.
'93 pickup 2WD
'85 pickup 4WD
Re: Pre 3.4 Swap Questions [Re: yotaman7] #921535 12/23/08 05:28 AM
kewlynx Offline
Keep an eye on fleabay. I believe you can use harnessing from 97-2001 to get all your connectors and what have you.
www.techinfo.toyota.com $10, 24 hr window, download your electrical diagrams. There's a sticky in the Taco section for FSM's here too. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921536 12/23/08 05:37 AM
yotaman7 Offline OP
Once I get my donor and know the year I will definalty be payin the 10 bucks for the correct EWD.
Are these diagrams very detailed and vehicle specific or more like the ones in a haynes manual.
'93 pickup 2WD
'85 pickup 4WD
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6402 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-10-22 00:09:05 UTC
