Re: IFS steering knuckle bushing replacement [Re: Vanishing_Point] #921568 01/23/09 04:39 AM
OOP'S Offline
I'm not trying to steal the thread, but do the roller bearings fit the solid axle as well? <img src="/forums/images/graemlins/smile.gif" alt="" />
No.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: IFS steering knuckle bushing replacement [Re: MAC] #921569 01/23/09 06:08 PM
O
OutlawMike Offline
I hope this is not too much off topic.
I am curious why one would swap out the spindle bushing from the early, non-ADD IFS for the roller bearing ADD style?
I'm an ME by training and career, but sometimes overthink the real world. But, the advantage of a bushing is that it will handle far higher load and also tolerate far more contamination than a roller or needle type bearing of the same size. Also, their failure mechanism tends to be gradual over time rather some of the more dramatic failures of a roller bearing. But, bushings have far higher parasitic drag.
My understanding of the bushings versus the rollers/needles in the Toyota IFS is this:
In the first generation, they had manual hubs, so CV's and front diff were not turning as you rolled on pavement. Therefore the bushings at the spindle and the bushings in the diff at the stub axles did not turn.
When they went to ADD, the CV's are now always turning at the spindle. On the passenger side the stub axle is always turning in the direction of the tire. On the drivers side the disconnect lets the stub axle in the diff turn backwards in an open diff, as it is driven through the diff by the passenger side.
So, all four of the bushings in the front end would be seeing constant rotation and therefore their drag would cause a loss in fuel mileage.
They replaced all of the bushings with rollers and needles to decrease the rolling friction in the front end.
If you have hubs, why swap to rollers when you already have bushings that have a higher load capacity and will take far more dirt through the system without failure? Drag does not matter much offroad.
Thoughts?
Best Regards,
Mike Holdner
Re: IFS steering knuckle bushing replacement [Re: OutlawMike] #921570 01/25/09 03:20 AM
MAC Offline OP
Yeah Mike, that makes total sense to me. I'm going to stick with the bushings. I was getting the horrendous dry bushing noise from my right axle (I've had this before but this time it way worse than any I've ever heard). I found that the clip had come off and the axle and it was slopping around badly in the bushings having pulled in a little without the clip. When I pulled off the hub and checked it out it seemed like the axle was a very sloppy fit in the bushings. You could move it all around radially. I thought the bushings were surely shot from the slopping around with no clip for a long time. But... I dug out a spare spindle and axle and from a truck I stripped (axles/bushings were fine before I parted it). Low and behold the fit was just as sloppy. In looking at the axle shaft there is ony a machined surface for the inner bearing. The outer one has a lot of clearance. Seems that the hub keeps it centered and it does not even contact the inner surface. Seems like the outer bearing is just for thrust. I tried lubing it with my homemade lube tool and it was only minimally better. I think that since the axle was not drawn tightly into the inner bushing and a lot of crud/salt got in there and I must have not gotten it clean/lubed enough. I will re-lube again and see what happens. Still could be that the inner bushing is actually damaged but I am optimistic now and itching to try the lube again.
Concerning the lube, I have spoken to quite a few mechanical professionals (heavy equipment and general mechanical heads) and most recommended the moly based black/grey grease for brass alloy bushings in an application like this... but I know many people have had no problems with the high quality non-moly stuff. Toyota recommends moly grease also. So it seems in real life either works well as long as there is lube in there.
Keeping my fingers crossed on the bushings...
Re: IFS steering knuckle bushing replacement [Re: OutlawMike] #921571 01/25/09 04:54 AM
OOP'S Offline
Mike Holdner
As far as I am concerned not off topic a bit. Made me stop and think and it makes a whole lot of sense.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6104 MB (Peak: 0.7013 MB) Data Comp: Off Server Time: 2026-10-24 23:55:44 UTC
