Emergency Brakes #921872 12/21/08 07:01 AM
Superman Offline OP
Accidentally drove on my Emergency Brakes for about 2 miles today. Is that bad?
How do I adjust it?
Thank You
Clark
Tacoma PreRunner Double Cab V6 Automatic
3.4-liter V6 TRD
Re: Emergency Brakes [Re: Superman] #921873 12/24/08 06:41 AM
BIGBURLYNAKEDMAN Offline
Just 2 miles shouldn't be that bad -- not enough time to heat them up and warp the drums.
If you want to make sure you didn't warp anything, drive a few miles to get everything warmed up as usual, then, when approaching a stop sign or light, don't apply the brake pedal, but pull out the emergency brake. If you feel a pulsation while you're slowing, then your rear drums are likely out-of-round. You can get them resurfaced and throw some new shoes on, and that'll work most of the time.
Also, the rear brakes should be self-adjusting, provided they were adjusted properly after you last had them serviced.
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: Emergency Brakes [Re: BIGBURLYNAKEDMAN] #921874 12/26/08 08:16 AM
Superman Offline OP
Thank You! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Clark
3.4-liter V6 TRD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5927 MB (Peak: 0.6459 MB) Data Comp: Off Server Time: 2026-06-17 04:15:50 UTC
