DIY ceramic coating #922051 12/23/08 01:25 AM
Rauch_Off_Road Offline OP
Is there a DIY ceramic paint that I can apply myself to steel and aluminum parts?
(aka suprathepeg, aka Sean)
Re: DIY ceramic coating [Re: Rauch_Off_Road] #922052 12/23/08 02:52 AM
4Crawler Offline
I've used the DupliColor hi-temp ceramic spray paint and had pretty good results with it. The key is to let the parts air dry for a day or so then bake the painted parts in an oven @450F or so for an hour or two. Then shut off the oven and let the parts cool down inside the closed oven.
Re: DIY ceramic coating [Re: 4Crawler] #922053 12/23/08 11:32 PM
yodta Offline
Roger, do you have a separate oven just for your painted items?!?
you think this stuff would hold up on exhaust heat shields?
msg - '87 xtracab
Re: DIY ceramic coating [Re: yodta] #922054 12/23/08 11:54 PM
4Crawler Offline
Nope, just do it in the regular oven. If you let the paint fully dry there is not a lot of fumes off of it. Usually do it on a warm day with the windows open. There is a bit of odor for the first 30 minutes or so, then nothing.
I did the two EGR block off plates on my '85 engine header, this photo was after about 8 years use:
I sanded those down and repainted them and they still look like the day I put them back on and that has been 2-3 years now.
Re: DIY ceramic coating [Re: 4Crawler] #922055 12/24/08 01:12 AM
yodta Offline
nice.
wait, did you paint the header, too, or was that already coated?
msg - '87 xtracab
Re: DIY ceramic coating [Re: yodta] #922056 12/24/08 01:16 AM
4Crawler Offline
That is an LC header and it came already ceramic coated.
Re: DIY ceramic coating [Re: 4Crawler] #922057 01/01/09 02:49 AM
KiwiCowboy Offline
I would recommend that you use an electric oven just in case the paint was not throughly cured. I've heard of more then once of gas ovens exploding.
PHP: 7.4.33 Page Time: 5.221s Queries: 15 (5.217s) Memory: 0.6174 MB (Peak: 0.7076 MB) Data Comp: Off Server Time: 2026-10-24 04:42:23 UTC
