need to replace caliper
#922120
12/23/08 03:37 PM
i got one that is grinding and its like real heavy snow here so i wanted to take it off and just put one set of calipers on just till a nice day . Any tips on getting bolt out with out breaking them ? i broke one before and if it breaks them im done for , No money and parts yard is shut down till spring .
Re: need to replace caliper
[Re: catman25]
#922121
12/23/08 09:16 PM
I would replace both side at the same time, use some PB Blaster on the bolts and let them sit over night, I would not just throw on used ones. do you know it is the caliper ? are the pads worn down all the way ? how are the rotors ? do you live in the USA ? I know you said there is no money, if the pads are worn down I would throw on a set then save up for loaded cal's and maybe rotors.
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#922122
12/23/08 10:28 PM
i need to get by till nicer weather , thought pads could make it but guess not , been rough times latly , looking just to throw a pad on till better weather and hope other side last a while . by the time i get home its 6 and dark and cold and i cant drive metal to metal <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: catman25]
#922123
12/23/08 11:27 PM
I need to do a oil change and the cold is a biggy for me I have nerve damage in my hands and any cold my fingers go numb and hurt so bad I have to run hot water over them, maybe this Sat. they say it should be warmer, I know a lot of guys here get it colder but my body just can not take the cold anymore.
[Re: bombardj1]
#922124
12/24/08 03:50 AM
PB Blaster can be your friend... Where do you live? Kragen/O'Riley's has front pads for $20.00. PM me and I'll see what I can do to help you. Everet
[Re: Everet]
#922125
12/24/08 05:52 PM
Catman...check your pm. Get back to me quick!!! Everet
[Re: Everet]
#922126
12/26/08 03:16 PM
Catman...pm me with your phone number...I have something for you. Everet
[Re: Everet]
#922127
12/26/08 03:26 PM
sry havent been on , got brakes off.. fuuuuuking slider bolt broke in the harness , trying to find a place that sells those <img src="/forums/images/graemlins/frown.gif" alt="" /> need to drill old one out <img src="/forums/images/graemlins/frown.gif" alt="" /> thanks for the pm ... Any one know of a compatible slider bolt from another vehichle ?
[Re: catman25]
#922128
12/30/08 07:09 PM
Catman, Check your PM's again. I left you one with my phone number. Call me if you want, but get back to me so you can pick up your Christmas present. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Everet]
#922129
12/30/08 09:29 PM
u r a saint . ill grab your number and give ya a call . send me a pm . I just sent you one .
