Snow chains. Front, rear or both? #922141 12/23/08 08:59 PM
Seattlegti Offline OP
I'm running front only and so far so good. Snow is only a foot deep but the roads are iced over really bad so I figured front would be safer. Must've pulled 12 cars out this weekend.
What are you guys running???
[img][image]http://img95.imageshack.us/img95/9136/snowseattle08061ys0.jpg[/img][/image]
Have a great xmas all!
Re: Snow chains. Front, rear or both? [Re: Seattlegti] #922142 12/24/08 04:56 PM
DarkWolf40 Offline
My owners manual says to not run chains on the Rubicon. Not sure why that is, anybody know?
Re: Snow chains. Front, rear or both? [Re: Seattlegti] #922143 12/24/08 06:57 PM
BobRowe Offline
Sorry, can't help. We can't run chains here in Michigan.
Re: Snow chains. Front, rear or both? [Re: BobRowe] #922144 12/24/08 07:37 PM
4x4Wire Offline
Chains are not recommended on front of many 4x4s due to steering knuckle and brake configurations; especially disc brakes and IFS axles.
Drum brakes are enclosed with no exterior moving parts. Disc brakes do have exterior parts that can be damaged by standard tire chains.
Hence, manufactures warn against using chains on the front.
There are a number of new styles of chains being produced that are touted as being compatible with disc brake systems.
In the mean time, if you need chains, chain the rear only.
Loose fitting or improperly installed chains can damage brake lines....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Snow chains. Front, rear or both? [Re: 4x4Wire] #922145 12/29/08 10:18 PM
Guessing it's because the rear sway bar on JK Rubicons is really close to the inside of the tires.
Or Chrysler is just covering thier butt.
I've always run rear only until this storm hit, the thick ice under the snow made it impossible to drive without chains up front.
This is AFTER they plowed the roads. Just ice.
[img][image]http://img176.imageshack.us/img176/8715/snowseattle08055xo5.jpg[/img][/image]
Re: Snow chains. Front, rear or both? [Re: Seattlegti] #922146 12/30/08 08:26 PM
Brown81CJ5 Offline
I was up there for Christmas...that was the most snow i have ever seen without actually going to a mountain. My inlaws live in Bonney Lake. Their view is absolutely amazing of Mt Rainier...will have to post a few pics later when I get around to it...in the OT section.
The inlaws run studded tires and they seemed to work well.
In your pic above...it's funny that fresh cut trees drive carefully. <img src="/forums/images/graemlins/smile.gif" alt="" />
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Snow chains. Front, rear or both? [Re: Brown81CJ5] #922147 12/30/08 09:50 PM
PartyTruck Offline
I'm amazed that you use snowchains for something like that on a 4x4. You are better off using good snow capable tires with slightly less air in them than usual. Siping is also very good especialy if you sipe the whole tread, siping the middle and studding the outsides works well too if you think you need studs.
Last man I knew that used snowchains was my grandfather.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Snow chains. Front, rear or both? [Re: PartyTruck] #922148 12/30/08 10:04 PM
Brown81CJ5 Offline
Seattle does not normally get snow...just the surrounding mountains. Not normal weather for them. My inlaws had studded tires and those worked very well in the snow and ice.
Gun it and run it!
Re: Snow chains. Front, rear or both? [Re: Brown81CJ5] #922149 01/09/09 08:34 PM
I totally agree, I had my new BFG MT's siped before they were installed 2 months ago.
Still slipping and sliding all over the place at 15 psi.
Finally got to use that ARB air down thingy I got my in recovery kit for xmas though.
It was the freezing rain before the snow that killed us.
Water is receeding. We're heading out to Enumclaw after work to help with the cleanup.
Half expect Mt.Rainier to blow next. 2 blizzards, a flood, 70 MPH winds and wherehouse fire next door is a bit much in 2 weeks time.
Good call on greasing the hubs, I've been drinving through deep water for days...
Re: Snow chains. Front, rear or both? [Re: Seattlegti] #922150 01/10/09 01:35 AM
Brown81CJ5 Offline
My inlaws used to live in Enumclaw. Now they live in Bonney Lake. I guess it is good that they moved...they are on higher ground now.
Gun it and run it!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6322 MB (Peak: 0.7411 MB) Data Comp: Off Server Time: 2026-05-29 16:17:04 UTC
