intermittent starting issue
#922177
12/24/08 03:27 AM
Here recently only sometimes it doesn't want to start, it will turn over but won't fire. I do not have the original key as I had to have it re-keyed when I bought it, could it be a issue with the new key?
94 Zj custom suspension and other stuff 01 F250 tow hoe 5" exhaust 00'sporty 3" lift 235's
Re: intermittent starting issue
[Re: minydigger]
#922178
12/24/08 10:42 PM
no if it starts even sometimes I don't think the key is the problem, if it always turns over the igntion is at least turning the eng over, when it is running is there any cel light on ?
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#922179
12/25/08 01:21 AM
No check engine light it won't start, I thought it might be the key because if you kinda play with it a little it will start sometimes. Its getting to be a pain in the but as it usually does it when your in a hurry
[Re: minydigger]
#922180
12/25/08 01:36 AM
so when you say it won't start you mean the key does not want to turn ? is the steering wheel locked ? if the key always turns and if you wiggel it and to does turn and start, it is the key or the Ing. switch. try a few different keys. the switch could be warn out, what is your year ?
[Re: bombardj1]
#922181
12/25/08 03:56 PM
The key turns fine, the engine will turn over but not fire up and its a 2000.
[Re: minydigger]
#922182
12/25/08 04:31 PM
?? fuel filter, plugs, air filter, dirty throttle body, has the timing belt ever been changed ? bad gas.
on oil changes do not use fram, they do not have anti-drain back valves, you have a dry start up with them. get this wal-mart's tec-filters has a anti-drain back in them and they are 1/2 the price as the frams.
I would start with the fuel filter
[Re: bombardj1]
#922183
12/26/08 03:23 AM
Need to do the fuel filter, how could the timing belt cuase this issue?
[Re: minydigger]
#922184
12/26/08 06:17 AM
could have jump a few teeth, anyway Kia says to replace it every 60,000 miles. how many miles are on yours ? but it still might not be your problem, if you never changed your plugs read the sticky about it, ? where do you live ? VA I checked your profile.
[Re: minydigger]
#922185
12/29/08 05:46 PM
their is two main relay under the hood they are very bad for going out my did this would only start some time and it took me about a week to figure this out i had bought the kia for a little bit of nothing because no body eles had figured it out.
99 kia sportage 2 door tj coil spring rear spacers in front 31x10.5 sidewider tires cat exaust in the process of making a snorkel
