Page 1 of 5 1 2 3 4 5
The "Running 34" Tires Stock" Write Up #922330 12/25/08 01:23 AM
DRaider90 Offline OP
Introduction:
I have now had a season of wheeling to evaluate running 34" tires stock on a Gen 1 Montero/Raider. This write up actually covers 2 different 34" tires, the 12.5" wide TSLs, and the 9.5 wide TSLs when its done. I will cover the trimming needed, rubbing issues, power loss, and corrective measures. Pictures and tape measurements are included also. The pictures are 640x480, with a 1600x1200 high res link below them (my christmas present a Razr ve20 took the pictures). I tried to park the truck as level/flat as possible for this, but its not perfect.
Section 1: Vehicle Control Stats:
Vehicle: 1988 Dodge Raider with Off-Road Package
Engine: 2.6 Liter Inline 4 Cylinder with Weber Carb
Mileage: 145k miles on truck, 40k miles on new engine
Transmission: 5 Speed KM145
Gearing: Stock with rear Limited Slip.
Highway Driving: 10 miles round trip 6 days a week. And 120 miles round trip to Uwharrie for wheeling trips.
Off-Road Testing: Dry dirt, Rocks, Water, and Mud
Section 2: Wheel/Tire Stats & Info
There aren't many 34" tires out there. The most popular are the 33x12.5-15 TSL Bias Ply, 34x9.5 TSL-15 Bias Ply,34x10.5-15 LTB Bias Ply, and 34x12.5 TrXus M/T Radial. And yes that isn't a typo, the 33x12.5 TSLs are included.
33x12.5-15 TSL: 33.7" x 12.4" Actual Measurements, 60lbs Weight, 24/32nds tread
34x9.5 TSL: 33.8" x 9.5" Actual Measurements, 54lbs Weight, 27/32nds tread
34x10.5 LTB: 33.6" x 11.2" Actual Measurements, 58lb Weight, 22/32nds tread
34x12.5 TrXus M/T: 34.0 x 12.9 Actual Measurements, 64lbs Weight, 19/32nds tread
As you can see the so called 33" TSLs actually measure bigger than the 34x10.5 LTBs. So they are really a 34" tire. The only tire that won't be covered is the TrXuS which does measure larger at 34.0, but has less tread.
Section 3:Trimming and Hammering
This is the hardest part of course. You will need some kind of saw, a hammer, and grinder (optional). First off the front bumper end caps will need to be trimmed. There is a piece of metal that will be a good marker on where to stop. Besides it is pointless to cut back further than it, because the tires will hit that piece of metal. The other option is to take off the bumper end caps and don't even worry about cutting.
High Resolution 1600x1200
Next is to hammer the metal part of the splash guard/inner fender back. Here a buddy of mine Bill used a grinder to cut some off to allow to bend it back easier. This isn't a must, it just made the hammering easier. You will also notice by the hole on the left that the TSLs made the plastic trim piece on the fender a "self re-moving item" as it is no longer there.
Here is what you will end up with as resulting clearance with the tires on. You can also notice the other rear side black fender trim piece is still there, but it is battered being a rubbing point.
The rear won't need any modification, but I am guessing you could eliminate any possible rubbing (I haven't noticed any...if there is any a tiny bit). I also opted to put the tires with more tread in the rear to avoid having more rubbing issues up front.
[img]http://img181.imageshack.us/img181/7409/reartiresideviewon0.jpg[/img]
Section 4:Rubbing, Tire Tread Depth, and LTBs
First off is rubbing. While there aren't really rubbing issues in the back, there will still be rubbing in the front. Some of it can be fixed by removing the black plastic fender trim pieces that will probably be self-removal items anyway (aka the TSLs or similar tires will rip them off).
Rubbing is most common when: Making sharp turns (less than 90 degrees), changing grade levels on streets (going over bridges etc), and entering parking lots that have a drop off/incline. And this is primarily due to the massive outter lugs that the TSLs have. So you may not have any rubbing issues if you run some other brand of 34" tire.When the tires are aired down to 10psi on the trails, the rubbing is virtually eliminated.
Next is tire tread depth. Of course the TSLs I have are used and not new. They start with 24/32nds tread depth new at 33.7". So used the tires are a tiny bit smaller, and will fit better. So I put the tires with the most tread in the rear because they won't be turning/rubbing. And then the last tread in the front where rubbing at full turn would be an issue. Here is a comparison between the front tires, rear, and new.
[img]http://img72.imageshack.us/img72/7166/fronttiretreadexamplepv7.jpg[/img]
[img]http://img391.imageshack.us/img391/5808/reartiretreadexamplent6.jpg[/img]
[img]http://img168.imageshack.us/img168/8942/sparetiretreadexampleneee7.jpg[/img]
You can see there is a big difference between the front tires and new, but a much smaller difference betwen the rear and new. So its safe to say a new set of TSLs will fit, but you may need to do more hammering in the front. Worst case scenario is you end up doing a torsion bar crank in the front.
Say you opt for the LTBs which measure 1/10th of an inch smaller than the TSLs new, and have 2/32nds less tread. So you should have no issues running a new or used set seeing they are smaller. But just for reference I took some pictures of some good tread 34x10.5 LTBs off of Lorenzo's Isuzu and compared them to the TSLs on the back of my truck.
[img]http://img152.imageshack.us/img152/4214/33tslvs34ltbcomparisonzn3.jpg[/img]
High Resolution 1800x1200
[img]http://img184.imageshack.us/img184/6445/33tslvs34ltbcomparison2ty6.jpg[/img]
Section 5: Clearance Gains
The whole point of putting bigger tires on is to gain clearance. So I took some measurements from the rear differential, lower most skid plate, and door/rocker panel so you know what your gains will be vs stock/your setup.
[img]http://img187.imageshack.us/img187/482/doortogroundclearancefp8.jpg[/img]
[img]http://img187.imageshack.us/img187/473/reardifftogroundclearandh1.jpg[/img]
[img]http://img123.imageshack.us/img123/4614/skidplatetogroundclearazr3.jpg[/img]
Section 6:The 34x9.5s,Comparisons, @ Spare Tire
Of course my next set of tires are the 34x9.5 TSLs that measure 33.8" new with 27/32nds tread depth. The 2nd half of this write up will cover the 34x9.5s on 15x6 alloys, and possibly a t-bar crank-body lift but I figured I would give some info now considering I do have the tires here. Below are image comparisons of the 34x12.5 TSLs on the rear of my truck, the 34x9.5 TSLs on no wheels in the middle, and the new spare 34x12.5 TSLs on the outside.
[img]http://img265.imageshack.us/img265/7531/34x125newvs34x95usedir8.jpg[/img]
[img]http://img339.imageshack.us/img339/2421/34x125newvs34x95used2cy8.jpg[/img]
[img]http://img530.imageshack.us/img530/8927/34x95upagainst34x125hy3.jpg[/img]
[img]http://img75.imageshack.us/img75/2203/34x125new34x95used34x12sf4.jpg[/img]
[img]http://img185.imageshack.us/img185/7128/34x125usedvs34x125usedbx2.jpg[/img]
One of the often forgotten aspects of running bigger tires is fitting a spare tire on the back. Here is a picture of clearance between the spare tire (new) and the door handle cover.
[img]http://img185.imageshack.us/img185/4135/sparetiretodoorhandleclxa2.jpg[/img]
Section 7: Power Loss and On-Road
Power loss is always a big concern when moving up to bigger tires. And in this instance you have just about the worst case secenario (only the TrXus weighing more). The 34x12.5 TSLs weigh 60lbs and the 15x8 Street Locks with 3.75bs are as heavy as it gets with steel wheels. So its safe to say the 54lb 34x9.5s on the much lighter 15x6 Alloys will help in with my power loss.
The first thing you will notice is the truck won't take off extremely fast. Its a truck after all so that shouldn't surprise you. Then you will notice if you want to avoid downshifting in hilly areas you will be using 4th gear a lot more than 5th. If you don't use 4th gear and keep it in 5th going up steep hills you will have to either A.) Downshift or live with B.)going down to 35mph by the time you get to the top of the hill.
On the highway it will take longer to get up to the 65mph+ zone. But after you get up there, you can get up to 75mph+ without many issues as long as you don't get behind slow people or come upon a steep hill. Other wise its not that bad running the bigger much heavier tires. As long as you can live with driving your truck like a truck and not a car you will be just fine.
Section 8: Conclusion
In conclusion yes you can run 34" tires stock with some trimming and hammering. But this is not to say you don't want to at least do a t-bar crank to eliminate rubbing up front. I haven't done it yet, but its only my list of stuff to do trust me. If you add a 2" Body Lift to this you should be pretty much set to tackle what ever you point your Montero/Raider at. Put on the 2.5" Toyota Shackles in the rear also (combined with the t-bar crank and body lift) and I would say you would be really tempted to move up to 35"s or 36"s. So while nearly bald 35" BFGs have been run stock, its safe to say if you want to buy new/good used tires 34" is the max unless you at least do a t-bar crank and possibly a lift. Part 2 of this write up will come later on this month/January when Angelo's 34x12.5 TSLs come off and the 34x9.5 TSLs go on.
[img]http://img184.imageshack.us/img184/230/overallshotmb6.jpg[/img]
Re: The "Running 34" Tires Stock" Write Up [Re: DRaider90] #922331 12/25/08 01:39 AM
justice Offline
Enough with the close ups. Show a picture of the whole truck already! <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: The "Running 34" Tires Stock" Write Up [Re: justice] #922332 12/25/08 02:28 AM
Section 8a: Wheeling Testing
I forget you guys haven't been up to date with the Uwharrie trips so most haven't seen all the wheeling shots of the Raider on 34"s from the year. Here are some from October.
High Resolution 1200x1600
High Resolution 2048x1600
And here are some videos even:
http://www.youtube.com/watch?v=okdXrMeV2Fo&feature=channel_page
(My truck is first)
http://www.youtube.com/watch?v=Xh7TImnsAT0&feature=channel_page
(My truck is 2nd, the one sitting there on the right hand side waiting while the 1st goes up)
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: The "Running 34" Tires Stock" Write Up [Re: DRaider90] #922333 12/25/08 07:19 AM
don Offline
I like the tire size comparisons, with the clearance pics.
Any data on wheel offset or backspacing?
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: The "Running 34" Tires Stock" Write Up [Re: don] #922334 12/26/08 01:01 AM
Out of the backspacing and offset I do know the offset (quoted above). 3.75bs seems to be a good amount to fit 12.5" wide tires in most scenarios with minimal/no rubbing.
Re: The "Running 34" Tires Stock" Write Up [Re: DRaider90] #922335 12/29/08 09:17 PM
PART 2: After the T-Bar Crank
Section 1: Gained Clearance
While I was over at Mark's (Sandhill Raider) he cranked the t-bars on the Raider. The gain in the front was about an inch. And now the rubbing issues with the front tires is virtually gone. It makes a huge difference. I didn't exactly measure from the same points on the sides of the fender as last time, but the top of the fender measurement is dead on.
(Keep in mind Mark's Raider has a T-bar Crank too)
Section 2: The 32x11.5 vs 34x12.5 Comparison
We took the spare tire off to do a comparison on Mark's Raider. In rear are 32x11.5 BFG A/T on stock steel 15x6, and sitting up front is the 34x12.5 on 15x8.
Re: The "Running 34" Tires Stock" Write Up [Re: don] #922336 12/30/08 01:54 AM
FatTony Offline
Ahh, the familiar 2.6L Bog.
Wheel info would be cool as stated above, also I'm assuming you're running a sway bar. My 33's still rub with cranked torsion bars, added rear leaves, longer rear shackles, and a body lift, but I'm running no sway bar, no rear bump stops, and 10" rims with 4" B.S.
88 Raider sas, doubler, boggers
Re: The "Running 34" Tires Stock" Write Up [Re: DRaider90] #922337 12/30/08 05:32 AM
To double re-quote myself from the above posts:
And to quote straight off the website:
Pro Comp Rock Crawler Steel Wheels Black 152 Series 15x8, 6x5.5, 3.75" Backspacing, Painted Black Finish
I still have my sway bar yes, the rims are only 8" wide, and have 3.75" BS. The only thing that has been done is the bumper end cap trimming, hammering of the splash guard, and now the torsion bar crank. And the t-bar crank of about an inch solved the rubbing issues on road. As far as off-road goes I haven't gotten to try it, and won't probably till April. But rubbing wasn't a big issue off-road, it was on-road with the tires aired up to 26psi when I had the rubbing issues. So I am sure off-road it will just give them more room to stuff and eliminate any of the very rare/minor rubbing there was (compared to on road when there was much more rubbing at full turn etc).
Re: The "Running 34" Tires Stock" Write Up [Re: DRaider90] #922338 12/30/08 10:27 PM
coalburner78 Offline
I'm running 31x10.50 on stock wheels with no bump stops and they rub in all 4 corners
87 raider,soon to have toy axles,TBI 318,R150 5spd,dana 300!. 78 ramcharger 5.9 cummins powered, 67 coronet 500 383/727
Re: The "Running 34" Tires Stock" Write Up [Re: coalburner78] #922339 12/31/08 12:59 AM
Are you driving a Wrangler? <img src="/forums/images/graemlins/lol.gif" alt="" /> J/K
Cool thread Eli. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6716 MB (Peak: 0.8450 MB) Data Comp: Off Server Time: 2026-05-29 23:57:29 UTC
