tacomas bogging down, replaced a ton and cant figure it out #922480 12/26/08 03:11 AM
tacoma4x4 Offline OP
hey guys i have a 2000 tacoma 3.4 v6 and it does nothing but bogg down and sputter. if i try to drive it, it brely goes no matter how much gas i give it, even at idle it skips a beat and then boggs when u give it gas.
ive put a intake on it, gutted both the cats, put all 3 new coil packs and wires on, bosch platinum +4 fusion plugs, a new throttle positioning sensor, cleaned the MAF, changed the coolant temp. sensor and im running out ideas
anyone have any suggestions?
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: tacoma4x4] #922481 12/26/08 03:34 AM
kewlynx Offline
Get rid of the Bosch platinums and put some NGK's in there for starters.
When's the last time the fuel filter was changed?\
T'body clean?
**ubi apis- ibi salus**
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: tacoma4x4] #922482 12/26/08 09:19 AM
humanoid Offline
Exactly, get rid of those Bosch plugs and put in some of the Denso or NGK dual electrode plugs, it's what required for your truck. There should be a sticker somewhere on the engine that specifically states that dual electrode plugs are required/recommended.
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: humanoid] #922483 12/30/08 03:13 AM
1
1986xtracab Offline
Did you put aftermarket coils and wires on? if you did toss them in the trash. Toyota HATE aftermarket ignition parts.
1986 xtra-cab 22re
stock everything
1991 bed
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: tacoma4x4] #922484 01/02/09 08:14 AM
hairytaco Offline
Backtrack and take out all the easy to remove stuff that you replaced. Replace with OEM parts and see what happens. Toyotas DO NOT like aftermrket ignition parts. I've learned the hard way. Air, fuel, and spark.....these 3 things are what make your vehicle run. Which did you mess with? <img src="/forums/images/graemlins/scared.gif" alt="" />
2008 Tacoma 4x4 6spd manual SR5 TRD
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: kewlynx] #922485 01/03/09 08:56 AM
scootn2nature Offline
put your cats back in
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: kewlynx] #922486 01/04/09 10:08 PM
thanks guys..i changed the fuel filter and then the mass air flow sensor and it fixed it. should i change the plugs to ngk? or leave the bosch in
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: tacoma4x4] #922487 01/05/09 12:07 AM
john_luttrell Offline
The Bosch will come back to haunt you; go to the parts store and get what came in the truck STOCK.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: tacoma4x4] #922488 01/05/09 08:47 AM
humanoid Offline
You can get the NGK or Densos, but the first thing you need to do is to rip those Bosch plugs out, they will bite you in the ass later on down the road.
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: humanoid] #922489 01/08/09 06:21 AM
yotaman7 Offline
I'm curious as to why Bosch plugs are so bad for toyota's. Can anyone explain or direct me to an explanation as to why they don't work well with toyota's. Just wonderin!
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.003s) Memory: 0.6356 MB (Peak: 0.7573 MB) Data Comp: Off Server Time: 2026-05-29 19:59:15 UTC
