Re: tacomas bogging down, replaced a ton and cant figure it out [Re: yotaman7] #922490 01/08/09 11:40 PM
BIGBURLYNAKEDMAN Offline
It's funny, I don't know why they say that either, however I've experienced poor performance from Bosch myself. I switched out a set of Bosch plugs AND wires with less than 10k miles on them for the factory plugs/wires because the truck was running like crap with Bosch.
However, my old '86 BMW LOVED those Bosch Platinum 4 plugs. Ran so much better with them. But they don't agree with the Toyotas too well, I guess.
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: yotaman7] #922491 01/09/09 05:16 PM
humanoid Offline
I'm curious as to why Bosch plugs are so bad for toyota's. Can anyone explain or direct me to an explanation as to why they don't work well with toyota's. Just wonderin!
Not sure really why, maybe they're made inferior to NGK or Denso?
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: humanoid] #922492 01/11/09 08:31 PM
G
Greg_Canada Offline
Japanese plugs work well with japanese cars, and german plugs work well with german cars.
89 4Runner
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: yotaman7] #922493 01/12/09 02:42 AM
kewlynx Offline
Sparkplugs have different temperature ranges, and the Boschs are too hot. I just pulled some Autolite plugs that were completely blue along with a toasted plug wire not too long ago out of my 2.7 4Runner.
Short article, but informative
http://www.ngk.de/Spark_plugs.649.0.html
**ubi apis- ibi salus**
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: kewlynx] #922494 01/24/09 05:23 AM
David1 Offline
I am trying to change the fuel filter on my 96 Tacoma SX and I'm having some trouble. Do I need to take the bracket completely off in order to change it? The problem I'm having with the truck, which started today, is while I was at a stop light the truck quit running. It would start up with no problem. Read a previous post and there was mention of replacing a mass air flow sensor. I'm no mechanic by any means so any help and advice is welcomed. Thanks for your time.
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: David1] #922495 01/25/09 12:52 AM
David1 Offline
I got the new filter installed. A word of advice. Reinstall the original washers on the new filter if it's an aftermarket filter. The washers that came with the new filter were too small and began to leak after starting the motor. I hope this solves my problem. If not, I'll try cleaning the mass air flow sensor next.
Re: tacomas bogging down, replaced a ton and cant figure it out [Re: yotaman7] #922496 01/25/09 10:03 AM
motoman515 Offline
I started getting a cel code for misfire cylinder #1. Went to a Toyota/Lexus Repair shop. First thing he asked was what kind of plugs I was using. I said Bosch. He said to get them out of there. Toyota's Denso stuff doesn't like anything but Denso or NGK Plugs. Cleared the code and replaced the plugs. No Problems since.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6266 MB (Peak: 0.7164 MB) Data Comp: Off Server Time: 2026-06-07 04:41:51 UTC
