Do they make a diff spool for the 87 montero 2dr stock rear end?
#922707
12/28/08 10:48 PM
Im not sure if they do but it would be nice to lock up the rear end!!!
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
Re: Do they make a diff spool for the 87 montero 2dr stock rear end?
[Re: 87monty]
#922708
12/29/08 12:08 AM
No. The only aftermarket option is ARB.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#922709
12/29/08 12:21 AM
a handfull of 7018 rods melted in there should do the trick
87 raider,soon to have toy axles,TBI 318,R150 5spd,dana 300!. 78 ramcharger 5.9 cummins powered, 67 coronet 500 383/727
[Re: justice]
#922710
12/29/08 01:11 AM
I herd some people are going with the toyota tacoma rear end for gear and locker options?
[Re: 87monty]
#922711
12/29/08 03:40 AM
I herd some people are going with the toyota tacoma rear end for gear and locker options? Dunno where you herd that at, but no not really. BobShaw is the only one I know of that put a yota axle in his truck. DIY cheap swap is the montero sport locked diff, or weld your diff up.
[Re: LandRaider]
#922712
12/29/08 05:35 AM
Just a bit of advice in case you do decide to weld it up. Do not remove the thrust block in the center of all the spider gears. Not being to much of a welder, i had a shop do mine and they decided to remove my thrust block, at the time i didn't know it's purpose, but it caused a axle shaft to blow apart, no fun at all. <img src="/forums/images/graemlins/barf.gif" alt="" />
[Re: PA_JERO]
#922713
12/29/08 05:42 AM
my spider gears are welded to that thrust block,and everything else.
[Re: PA_JERO]
#922714
12/29/08 05:44 AM
well i recommend buying a sport rear end for 200-300 dollar range this will get you an air locker, stronger axle and in most cases disc brakes. It's a simple swap, but if you want to be a cheap ass, you can send me a bare diff (no ring gear) and i'll weld it up for you. Like PA_JERO said don't forget the thrust block.
[Re: LandRaider]
#922715
12/29/08 08:51 AM
I herd some people are going with the toyota tacoma rear end for gear and locker options? Dunno where you herd that at, but no not really. BobShaw is the only one I know of that put a yota axle in his truck. DIY cheap swap is the montero sport locked diff, or weld your diff up. I'd go with the locked diff option if you drove it on the street.. I drove Bob Shaw's truck with the Detriot locker in it.. it felt real funny driving on the road and punching the gas with the 4.3 making it lock the rear end <img src="/forums/images/graemlins/lol.gif" alt="" /> (lack of sway bars would do that too) Yeah man, so what kind of wheeling you doing with your truck anyway? LSD rears work pretty well ya know?
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: TOASTY]
#922716
12/29/08 03:56 PM
What year sport would have this air locker in it?
