Interesting fact about the T-100... #922978 12/30/08 09:45 PM
BamZipPow Offline OP
According to this website, the 1993 T-100 4WD only came in a 5-speed transmission. In 1994, they gave it the option of the 4-speed automatic. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Interesting fact about the T-100... [Re: BamZipPow] #922979 01/04/09 01:58 AM
wsquaredodie Offline
Wrong. My 93 SR4 3.0 4by has the auto.
trafdlo
Re: Interesting fact about the T-100... [Re: wsquaredodie] #922980 01/04/09 02:21 AM
CJMT100 Offline
Ah but question is, was it sold as a 94 or 93?? Sometimes depending on assemble date options you wouldnt think possible are there.
Re: Interesting fact about the T-100... [Re: CJMT100] #922981 01/04/09 04:48 PM
Early 93. From the numbers it was made in the first 15% or so of the total units produced. Somewhere in this forum is a list of numbers, years and quantities of vehicles produced.
trafdlo
Re: Interesting fact about the T-100... [Re: BamZipPow] #922982 01/06/09 03:32 AM
Go to www.toyoland.com/trucks/t100 - the 4 speed automatic was a little used option in 93 according to them
trafdlo
Re: Interesting fact about the T-100... [Re: wsquaredodie] #922983 01/06/09 06:35 PM
Perpetrator Offline
Also according to them, rear ABS was standard across the board. My truck has no ABS.
1997 T 100 4X4 ExtraCab
5 speed, White
Worthless factory bedliner
265/75/16 Firestone Destination A/Ts
Aisin Manual Hubs
90k miles
Re: Interesting fact about the T-100... [Re: Perpetrator] #922984 01/06/09 10:01 PM
Bill_R Offline
When I purchased my '93, the automatic was available in limited quantities and was available in the later part of the model year. I did see several on the lots around here, but with the 3.0, it wasn't a big seller for lack of power, mostly. The automatic probably made it that much more slower.
In my '93 brochure, it states: BRAKES: (rear) Drums with rear load sensing proportioning valve and rear wheel Anti-lock Brake System (ABS), with a footnote (operates in 2WD only). I would assume that the years following had the same set-up, but I could be wrong. I know that there is a dash-light that comes on when I start mine and it goes thru the lights and ABS or Anti-lock Brakes is one of them.
Bill Reid
'93 T100 SR5 4X4
'05 4Runner SR5 4x4 (wife's DD)
Re: Interesting fact about the T-100... [Re: Bill_R] #922985 01/07/09 05:46 PM
ErikB Offline
Toyota Moderator
My '97 has no ABS either.
http://home.4x4wire.com/erik
Re: Interesting fact about the T-100... [Re: ErikB] #922986 01/08/09 02:28 AM
My 93 SR5 has ABS and they work perfectly. Don't know why after reading all the stuff on this site about them, but they do. Never did anything in the last 2 years of ownership other than bugger the linkage up with WD40 on a regular basis
trafdlo
Re: Interesting fact about the T-100... [Re: wsquaredodie] #922987 01/09/09 05:23 AM
F
Flannelman Offline
Mine also has no abs and its a 97. I am also just fine having no abs as rear only in my opinion is just a hindrence.
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6385 MB (Peak: 0.7459 MB) Data Comp: Off Server Time: 2026-10-21 22:04:17 UTC
