2001 Rodeo Sport fuel gauge ?'s please #923364 01/03/09 03:48 AM
jeepdriver Offline OP
My daughter's Sport has developed a problem I believe is related to the fuel gauge sending unit. If the fuel tank is not absolutely full, and you park on a slight incline, the fuel gauge sticks on "EMPTY" and the check engine light will come on. This is intermittent problem, the check engine light goes on and off, and the vehicle passed emissions this week. A fellow Isuzu owner told me the gauge can go bad and cause this, there was a replacement kit for the sending unit that cost about $85.00 but labor to install this is about $250.00.
If anyone knows anything about this I would appreciate hearing about it.
Too many 4x4's, not enough time or money
Re: 2001 Rodeo Sport fuel gauge ?'s please [Re: jeepdriver] #923365 01/03/09 04:10 AM
MBB Offline
You will need to test to determine if the gauge or the sending unit is truly at fault. I sounds like an electrical connection problem somewhere, maybe in the sending unit itself, maybe not.
Even with the light off, if the check engine light came on it should have stored a code. Have you checked for stored codes?
Re: 2001 Rodeo Sport fuel gauge ?'s please [Re: MBB] #923366 01/04/09 03:48 AM
I am going to meet her and swap vehicles tomorrow, I will have time to check codes then.
Re: 2001 Rodeo Sport fuel gauge ?'s please [Re: MBB] #923367 01/07/09 01:54 AM
A
Amigo-2k Offline
It is the sending unit.
If you are the original owner with under 120k on the ticker it is a free fix.
I have the same issue and I have been waiting a month for the part to be in stock (my dealer thinks is need to replace the entire fuel pump, which they can, since I'm not paying for it).
Re: 2001 Rodeo Sport fuel gauge ?'s please [Re: Amigo-2k] #923368 01/08/09 12:27 AM
I am not the original owner, vehicle has 106,000 miles.
It threw the following codes.
Electronic Control Unit ID: 10
PO342
Camshaft Position Sensor A Circuit Low Input (Bank1 or Single Sensor)
PO463
Fuel Level Sensor Circuit High Input
P1627
PHP: 7.4.33 Page Time: 0.077s Queries: 15 (0.005s) Memory: 0.6076 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-10-24 08:16:13 UTC
