Page 3 of 4 1 2 3 4
Re: BEYOND FRUSTRATION !!!!! [Re: ghostraider] #924029 01/07/09 06:02 PM
tomzsix Offline OP
They performed a back pressure test, at low rpm's and high rpm's. They said the readings show possible air leaks at the carb.
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924030 01/08/09 12:48 AM
powerRam50 Offline
kind of what i was thinking.or maybe is has gotten a leak at the manifold to head?or one of the billion vac lines has a leak.
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924031 01/08/09 05:45 PM
ghostraider Offline
Sweet Work.
I love When A decision is made with Intelligence and not being hurried or having to guess.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924032 01/10/09 04:33 AM
tomzsix Offline OP
its been four days since the trouble. it sat in the driveway for a couple of days, and it drives without problems. I had to purchase a minivan for reliability issues. Now i can sit on the truck and take my time working on the problem. I will take others advice and start with the fuel tank and work towards the carb.
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924033 01/16/09 02:45 PM
RobCambo Offline
Found anything yet tomzsix?
I just found I have pretty much the same problem. The engine's fine on the lower part of the hill, but as I climb and press the gas pedal more, the engine violently coughs and dies. If I drop to first gear and crawl up the hill at low revs, then all is ok. Luckily, I live in a very flat area so hills are a weekend optional.
I've been told that it's the 2nd chamber in the carb that's not opening up when the required boost under load is needed. Not sure how accurate that is, but I'll be checking it out further.
Rob
Re: BEYOND FRUSTRATION !!!!! [Re: RobCambo] #924034 01/16/09 04:54 PM
LandRaider Offline
Try an ignition coil. Theyre cheap, and easy to replace.
Re: BEYOND FRUSTRATION !!!!! [Re: RobCambo] #924035 01/16/09 04:55 PM
powerRam50 Offline
the second barrel on my blue truck has not worked in years,and it runs fine.it dont have any high end power but there is no cough or die.same thing with my brothers 87 monty before we put the weber on.
Re: BEYOND FRUSTRATION !!!!! [Re: RobCambo] #924036 01/16/09 04:56 PM
ghostraider Offline
man i am sure glad i do not have a carb!
Maybe a can of Carb Cleaner?
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: BEYOND FRUSTRATION !!!!! [Re: LandRaider] #924037 01/17/09 03:39 AM
tomzsix Offline OP
why would you think its the coil?? Either they work or they don't, right?? I have never experienced a bad coil. How much are they? I am going to drain my gas tank this weekend and see what comes out. I don't trust my truck to even go to Kevin C's house. I would end up having to drive under 20 mph. Since now I have a glorious minivan, I can take my time on this trouble shooting.
Tom Tucker
Re: BEYOND FRUSTRATION !!!!! [Re: tomzsix] #924038 01/17/09 08:11 AM
LandRaider Offline
Years of Experience
Sometimes they fail, and stop working all together. Sometimes they fail, and short partially internally, and overheat. A weak coil will diminish under acceleration, and load. Ive troubleshot a 2.6 raider with this exact problem before. Swapped carb's, and computers, and all other things in between.
How much are they?
About 20 bucks, and well worth your time to try.
Can't hurt to drain your gas, but i'd put a new coil in it first.
Let us know whatever fixes it.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6444 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-10-24 02:34:03 UTC
