Obviously, I am looking for an alternative diagnosis to a broken piston ring.
1986 225T Trooper turbo diesel running on regular diesel for Winter.
Symptoms:
1. Lost power, occasional misfire, not a steady miss.
2. lots of smoke from exhaust, engine oil leaking from loose exhaust pipe fitting at manifold.
3. Engine cycling (revs slightly on its own) like it is burning oil in piston(s).
4. Engine oil very low, after I checked and added oil the previous day.
5. Early stage rattle at acceleration, not doing that anymore.
It was cold and dark on my drive home from work last night, I kept an eye on oil pressure which never fluctuated. I assumed (hoped) it was a clogged fuel filter, so I decided to drive it home the ten miles at low RPMs. It was smoking badly, but sounded well enough to continue, I thought, once I was a few miles from town I figured it wasn't hurting the engine so I kept on. I did pull into the last gas station before leaving when I thought maybe it was low on diesel, but at the station and under the lights it sounded fine and wasn't smoking too badly.
Oil light came on a couple of days ago going around a sharp turn. In the past this meant it was time to add a quart, Unfortunately, I was totally broke after the holidays and put off adding oil for two days (until Friday) and 50, maybe 75 miles. I added this symptom because I know it makes it hard to diagnose without all the issues being disclosed.
This morning I cleaned out our new workshop and checked and filled the oil which was empty, then started the engine. It started normally, sounded fine, then after five minutes, it started increasing in RPMS to about 1000 from 800. I watched oil blow out the exhaust dough nut at the manifold and shut it down which it did normally, so I am speculating it isn't a leaking turbo seal. The oil must be getting in and out somewhere else.
Don't know, but it is in the shop now and I will start looking further. I don't have a diesel compression gauge, so I am guessing it is time to pawn the silverware and buy one.
What do you think?
I'm screwed, huh?
Images
Looking down at exhaust manifold - pipe connection on right side of image
Looking over tire at exhaust (not a good shot, I sort of missed the exhaust pipe manifold connector)
Gratuitous shot of the new shop with the Trooper inside.
