bending HREW tubing #924677 01/08/09 06:15 PM
Kookadala Offline OP
Is there a difference between a pipe bender and a tube bender? I see pipe benders for sale real cheap at Northern Tool or Harbor freight for up to 2 inch pipe for about 100 bucks. Can I use a pipe bender to bend 1.5" 0.120 wall HREW tubing for my exocage?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: bending HREW tubing [Re: Kookadala] #924678 01/22/09 09:16 PM
4x4Wire Offline
In general, "pipe" is of thicker wall material and often used for gas lines, conduit, or water pipe.
Most pipe benders have a single curved surface at the point of bend where a tubing bender will be an enclosed case around the point of bend.
In other words, you can use a pipe bender in place of a tubing bender. However, your bend will not be a smooth, rounded bend. At the sharpest point of the bend, it will have a "flattened" look.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: bending HREW tubing [Re: 4x4Wire] #924679 01/23/09 06:12 PM
Thanks, I pretty much found out from Pirate that a $600 tubing bender is the way to go for nice multiple bends in a single tube. A reasonable one seems to be this tube bender from Pro Tools.
Re: bending HREW tubing [Re: Kookadala] #924680 01/24/09 05:46 AM
4x4Wire Offline
If you are looking for clean bends, the $$$ spent are worth it.
The budget minded can get by with the cheaper variety....
John Stewart
Editor - 4x4Voice
Re: bending HREW tubing [Re: Kookadala] #924681 01/27/09 01:10 PM
NathanC Offline
Tube and pipe also have different diameters. Pipes have nominal size designations while tubing has tighter tolerances that are held to the OD.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: bending HREW tubing [Re: NathanC] #924682 02/27/09 09:18 PM
G
Greg_Canada Offline
Get a pro-tools bender, i love mine (i think another company named, JD2? makes a similar one.
89 4Runner
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6117 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-10 01:36:49 UTC
