Door handles, what is the good fix? #924741 01/09/09 04:36 AM
G
GTFD Offline OP
Broken door handles won't actuate the door linkages, the plastic tabs are broken off. I've got one handle removed for inspection. What is the good fix? Looks like any other plastic handle will just break again. Has anyone figured out the cheapo long life fix? Appearances aren't too important right now. Thanks.
Re: Door handles, what is the good fix? [Re: GTFD] #924742 01/09/09 07:31 AM
BamZipPow Offline
Yes...the cheapo fix it to line up the parts and drill a hole through the broken bit and handle. Put a nail through there and epoxy it in place. It's been working fine on my truck fer over 2 years now. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Door handles, what is the good fix? [Re: BamZipPow] #924743 01/09/09 09:58 PM
G
GTFD Offline OP
The broken piece isn't in the door bottom on my driver's side. Any ideas for fix without the broken piece? thanks.
Re: Door handles, what is the good fix? [Re: GTFD] #924744 01/10/09 12:57 AM
garym Offline
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-07 08:37:43 UTC
