Door handles, what is the good fix?
#924741
01/09/09 04:36 AM
Broken door handles won't actuate the door linkages, the plastic tabs are broken off. I've got one handle removed for inspection. What is the good fix? Looks like any other plastic handle will just break again. Has anyone figured out the cheapo long life fix? Appearances aren't too important right now. Thanks.
Re: Door handles, what is the good fix?
[Re: GTFD]
#924742
01/09/09 07:31 AM
Yes...the cheapo fix it to line up the parts and drill a hole through the broken bit and handle. Put a nail through there and epoxy it in place. It's been working fine on my truck fer over 2 years now. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: BamZipPow]
#924743
01/09/09 09:58 PM
The broken piece isn't in the door bottom on my driver's side. Any ideas for fix without the broken piece? thanks.
[Re: GTFD]
#924744
01/10/09 12:57 AM
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6012 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-09 21:57:34 UTCValid HTML 5 and Valid CSS
