1997 Mazda halfshafts #925052 01/11/09 04:50 PM
Brown81CJ5 Offline OP
Need to change the cv axles on my wifes '97 Mazda Protege. When we did the shafts on my friends saturn the diff fluid leaked out when one of the shafts was pulled (can't remember which side). Does the mazda do the same thing?
And are there any tips or tricks that anyone cares to share...maybe a certain tool I might need, or will make things easier?
Thanks
brandon
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 1997 Mazda halfshafts [Re: Brown81CJ5] #925053 01/11/09 05:46 PM
Adam F Offline
all front wheel drives will leak when you pull the cv. jack it up on that side so the fluid cant run out. use a prybar to get the axle out.
97 4R, stock, daily driver
Re: 1997 Mazda halfshafts [Re: Adam F] #925054 01/12/09 01:45 AM
So do it one side at a time? Thanks for the info. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Gun it and run it!
Re: 1997 Mazda halfshafts [Re: Brown81CJ5] #925055 01/12/09 03:53 PM
Adam F Offline
If your worried about loosing fluid, yes. Otherwise, do them both and let it run out, and refill it later.
Re: 1997 Mazda halfshafts [Re: Adam F] #925056 01/13/09 04:49 PM
hazy_daze Offline
Prior to pulling the shafts, make sure the output seals aren't leaking. If they are, now's the time to replace them. IIRC, taking the strut loose from the knuckle allows enough swing to get the axle out of the hub. You shouldn't have to take the balljoint or the tie rod loose, I think... Also, make sure the new axle has a good clip on the end. I've see reman axles with old clips before, that's just asking for trouble. If there's any doubt about it, pick new ones up from the dealer. Shouldn't be but a couple bucks apiece, at the most. As far as quality of parts goes, be sure to get a price on a new axle. Many times they're not much more than a reman and the quality is alot better. My .02 <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1997 Mazda halfshafts [Re: hazy_daze] #925057 01/13/09 05:49 PM
Adam F Offline
Usually I have to remove the bottom ball joint, but leave the tie rod end and upper ball joint attached. That will allow me to swing the whole knuckle out of the way to pull the shaft through.
Re: 1997 Mazda halfshafts [Re: Adam F] #925058 01/13/09 05:58 PM
hazy_daze Offline
I was thinking the nut for the lower ball joint was pretty hard to get to, like in between the lower control arm and the joint itself. And this car doesn't have upper ball joints, the strut attaches directly to the knuckle.
Re: 1997 Mazda halfshafts [Re: hazy_daze] #925059 01/13/09 09:38 PM
Adam F Offline
I see. Autozone.com has a free repair manual online thats pretty good. Check it out.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6240 MB (Peak: 0.7223 MB) Data Comp: Off Server Time: 2026-05-29 18:24:24 UTC
