tranny sawp #925544 01/13/09 05:14 AM
riding4him Offline OP
I have 2 complete troopers2.8 v6 4x4. 1 is a standard and the other a auto. I want to put the standard tranny in the automatic vehicle Is there anybody out there that can give me info on what all i need to do this swap?? Like what all do i need to take off the standard to make it work. Please help.
Re: tranny sawp [Re: riding4him] #925545 01/15/09 05:17 PM
What will i have to do with the wiring for the auto? Does the standard have a wiring plug that goes to it? Also were the clutch will bolt up in the Automatic vehicle there is the ecu or a fuse box and i dont know how i will relocate it. I know that it is alot of questions!! Any answers will help!! Thanks
Re: tranny sawp [Re: riding4him] #925546 01/15/09 07:24 PM
muskyamigo Offline
It will be easier since you have both vehicles and therefore all the parts. The fuse box will have to get moved, can"t really say how, slide it over and screw it back down?
You'll need pedals, clutch linkages, the crossmembers will need to be swapped.
The wiring harness may unplug and you can remove it but there may be othe things on it that are still needed. on mine the O2 sensors are also on this wiring harness.
Whats wrong with the manual trans vehicle? Would it be easier to swap the good parts over to the Troop with the maual trans already in it?
-Mike
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
Re: tranny sawp [Re: muskyamigo] #925547 01/15/09 07:44 PM
The auto vehicle is alot nicer powerwindows, nicerbody but it has a blown engine. So i put the motor out of the standard trooper in it, but the tranny is leaking from the torque converter so i want to put the standard tranny in it now. I put a new (front pump seal) in the automatic before i installed the new motor but it is still a leak!!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6007 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-17 13:03:43 UTC
