Just another post on noise in front, with a definate answer. #925806 01/14/09 02:03 AM
jaboo5322 Offline OP
I guess on this one i was allready fairly sure the problem. Popping on right side, seemed to slip alittle also. Also right side had been sqeeking when locked. So finally had no forward pull, but lots in reverse. Found both e-clips towards outer side of shaft, and of course massive amounts of play in axelshaft. So to get to work tommorrow, belive it or not, I switched the manual hubs from either side, and now I have foward pull, and no reverse. Must be the way the hubs a worn internally. Hope axelshafts not ruined. Didn't know wich post to add this to, just figured, make new one. And to everyone else, if you can, don't be like me and wait till it's allmost to late when you hear noise. <img src="/forums/images/graemlins/shiner.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: Just another post on noise in front, with a definate answer. [Re: jaboo5322] #925807 01/14/09 10:08 PM
kellbell77 Offline
Same issue here, replaced the wheel bearings, not it, checked the slip joint, and finally had to replace the Half shaft. Good Luck. All the guys on here helped me figure it out, even tho it took 2 weeks, but now NO NOISE at all! Good Luck
2001 Tan Kia Sportage, has a K&N air filter, Warn Hubs but there's nothing really special about it, but my 7 year old loves my KIA cuz she sits up high!
Re: Just another post on noise in front, with a definate answer. [Re: kellbell77] #925808 01/20/09 11:30 AM
BAZINGA Offline
I just found out that I have to replace both front shafts on my sporty. Turns out that the spline on the shaft had worn down and the new manual Warn hubs didn't like it. As a backyard mechanic, I am not looking forward to this. <img src="/forums/images/graemlins/confused.gif" alt="" />
It took me nearly a year to figure out that this was the problem with my 4wd. The Kia mechanic was stumped as well! I only found the cause when I was confirming that I had stuffed my front diff. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5934 MB (Peak: 0.6472 MB) Data Comp: Off Server Time: 2026-07-09 17:35:57 UTC
