Jeep Tires #925909 01/14/09 09:09 PM
A
Amy Offline OP
What is the biggest width tires and height I can put on stock rims for a 2005 jeep wrangler tj the stock tires are 30 x 9.5 x 15. I have a 1" body lift.
Re: Jeep Tires [Re: Amy] #925910 01/14/09 09:51 PM
BigJim Offline
Amy my stock tj with them same 30 X 9.50 tires on it does fine in the wilderness and on the highway. By placeing taller tires on it I would lose 2 or 3 or even more miles per gallon and would lose horsepower on the highway.. So I don't plan on changing tire size. The cost, other than the tires, is too high for me.
Lots of young people put tall tires on their ride and think it LOOKS good... They don't understand that the Jeep, or whatever, is engineered to use a certain tire size. Changing tire size changes a LOT more than just the LOOK of the vehicle.
Re: Jeep Tires [Re: BigJim] #925911 01/15/09 01:03 AM
cuervo25 Offline
X2 and to bring you up on the times BJ anyone that just raises a vehicle,but don't go four wheeling, builds a high perfomance car but don't raise it, or where the term really came from dresses like and carries a skateboard around but don't skate are called posers. that being said the only reason to lift anything,add bigger tires ,change the gearing(which you WILL have to do) is if you use it offroad.
Seeing that more than likely (happened many times before) that you will ignore us and do it anyway we will break this down.I THINK your rims are 8 in wide the widest i think you can put on safely is 11 in maybe 12 in wide and as high as they make em, now the biggest that will fit on your jeep and still have room where it wont rub on anything I would say 31 x 10.50.
Once again if your not wheeling it don't do it. however if you plan on wheeling it there are other things that should come long before bigger tires. research the net on what to do,how to build a rig the right way and so on.
Re: Jeep Tires [Re: cuervo25] #925912 01/15/09 03:13 AM
A
Amy Offline OP
Thanks for the info.
Re: Jeep Tires [Re: Amy] #925913 01/15/09 07:11 PM
jstritec Offline
Just to play devil's advocate, there is something to be said for looks! It may well get you laid!
<img src="/forums/images/graemlins/smile.gif" alt="" />
80 CJ-7.
It runs
Re: Jeep Tires [Re: jstritec] #925914 01/15/09 07:59 PM
BigJim Offline
I don't know dude! Might be, a gal being turned on by tall tires could be specting more than you could lay on the line...
Me? I'll just stick to shiny paint and flashy chrome.
Re: Jeep Tires [Re: BigJim] #925915 01/16/09 12:13 AM
jstritec Offline
Good point, but that only matters once you pop the hood. Big ones look good but nothing worse than running into a situation where you can't get it up. While too much rubber at full stuff can lead to excessive wear, that must be weighed against the likelihood of scraping your undercarriage and ripping off important parts from your rig. Either way, eventually you're gonna have to open up the rear end, and you know that can get messy, not to mention expensive.
80 CJ-7.
It runs
Re: Jeep Tires [Re: jstritec] #925916 01/22/09 05:09 AM
80CJ Offline
Boy, you don't beat around the bush, do you?
Re: Jeep Tires [Re: 80CJ] #925917 01/25/09 02:22 AM
jstritec Offline
Ha!
Well, you should never go wheeling alone, or sooner or later you will have to take matters into your own hands. I once got stuck in a hole so deep I didn't have enough cable to winch myself out!
I should stop now.
80 CJ-7.
It runs
Re: Jeep Tires [Re: jstritec] #925918 01/27/09 02:37 AM
cjensen Offline
LOL! U bunch are on fire today!
I just put new shoes on "Silver"....Super Swamper TSL and new black rims. Chose 29" x 9.5" 15lt. This actually is a good compromise with the tj standard, with no lift. They look great and roll real nice. The grab and traction is perdy damn good too.
C.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6359 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-06-10 01:33:25 UTC
