Which rear axle upgrade ?? #925921 01/14/09 09:21 PM
Staceman Offline OP
With limited funds.
Do YOU think that I would be better off replacing my entire (narrow) 85 axle housing with a 86+, keeping it stock, using my diff, of coarse.
OR
Keep my fine housing and newer shoes and upgrade the shafts with Chromoly, like Marlin or USA Alloy.
I can do 1 or the other. Also keep in mind that with a newer axle, I will have to re-fab my custom shock mounts "/\".
Suggestions are much appreciated. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Which rear axle upgrade ?? [Re: Staceman] #925922 01/14/09 11:18 PM
Adam F Offline
What are you trying to gain?
The newer IFS axle will give you 3 more inches of width, and larger drum brakes. No strength upgrades that I'm aware of.
Chromo shafts will be the only thing that gives you strength
With a stock motor, I dont see the point of upgrading to Chromo. I think you would benifit more with a wider axle and larger drum brakes. Re-fabbing the shock mounts on the axle is no big deal.
97 4R, stock, daily driver
Re: Which rear axle upgrade ?? [Re: Adam F] #925923 01/14/09 11:48 PM
Staceman Offline OP
Yep, just strength. Thinking of going 37's next time around. Currently I'm running 35's, with 4.7's in the case with no issue (also wheel spacers). But later may be going 37's and a Dual Ultimate setup. Can a stock rear axle shaft hold up to that kind of torque? Would like to keep it Toyota, not a D-60 or anything.
Re: Which rear axle upgrade ?? [Re: Staceman] #925924 01/14/09 11:48 PM
Staceman Offline OP
PS, Nice Avatar Adam!
Re: Which rear axle upgrade ?? [Re: Staceman] #925925 01/15/09 12:00 AM
Scerb Offline
I've only HEARD of a few cases of rear shafts breaking. Get the late style housing, and then upgrade to shafts later if you want. Then you'll have the best of both.
Re: Which rear axle upgrade ?? [Re: Scerb] #925926 01/15/09 02:44 AM
OOP'S Offline
It took me over 12 years to break a stock IFS rear axle. Running a dual ultimate most of the time. I would do the wider IFS axle.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Which rear axle upgrade ?? [Re: OOP'S] #925927 01/15/09 03:35 AM
G
Greg_Canada Offline
Trail-gear sells an upgraded axle as well... not too pricey (but i know lots of people hate them)
89 4Runner
Re: Which rear axle upgrade ?? [Re: Staceman] #925928 01/15/09 03:43 AM
Adam F Offline
<img src="/forums/images/graemlins/cheers.gif" alt="" /> Thanks!
Like the others said, the stock rear should hold up, no problem.
Now, in my case with a V8, I'm going to need those chromo rear axles here shortly.....debating between chromos in the rear and longs up front, or D60/14b
Re: Which rear axle upgrade ?? [Re: Staceman] #925929 01/15/09 03:01 PM
grandeyota Offline
I'd save the money on the chromo shafts. You can get junkyard stock replacements really cheap.
I've yet to break a stock shaft in 10 years of running 33-36's. I've have gone through my fair share of ring+pinions.
Fur clog in the sausage grinder
Re: Which rear axle upgrade ?? [Re: Adam F] #925930 01/15/09 04:26 PM
ErikB Offline
Toyota Moderator
I think your rear ring and pinion will be your weak link with that extra torque. Throwing chromos in the rear would probably be a waste of money...
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6430 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-07-09 17:36:13 UTC
