97 SR with blown motor #926177 01/16/09 04:12 AM
dolomiti Offline OP
I am looking at a really nice 97sr with a blown motor. According to the old man, the engine got hot, lost power and never restarted. My questions are:
1. Is this engine rebuildable
2. If so, what is the cost (assuming I am not doing the work)
3. If it needs a new engine, what is the cost for the engine and the install?
I want to spend at or below $2000.
1998 Mitusbishi Montero (winter package)
1987 Land Rover One Ten
Re: 97 SR with blown motor [Re: dolomiti] #926178 01/16/09 05:55 AM
For $2k and no work youself, I think the best you can hope for is a used motor that someone else installs.
Re: 97 SR with blown motor [Re: dolomiti] #926179 01/16/09 06:49 AM
87Montero Offline
Been there with that same motor.. I picked up my old SR for $400 bucks though in the same situation...you'd be surprised how tough they are... granted you'd probably spin the bearings in about 1000 miles like I did.. If it turns over.. you could probably change the fluids and I bet it would start right up and drive.
You're looking at a pretty penny for a bottom end rebuild, and getting the heads shaved if they are warped. That still doesn't include the reason why it even overheated in the frist place. In your case, you may want to look at one of those JDM long blocks, but you'd loose the montero cams unless you swap those over too. The 3.5 motor seems to be the most expensive mitsubishi engine I've touched. (3.8 would probably be more)
It'll be alot of work to run through the whole engine.. After what I've been through with engines, its best to leave no stone unturned... maybe I picked that up from FrankR? To have someone else do the work to install even a JDM engine.. it's not quite as much work as the DOHC version of that truck by far.. but its no walk in the park anyway.. You'd pay far more for the engine/getting it swapped in than you'd pay for the actual truck in the end. It would be a good summer project if you're willing to learn like I did.
I'm jealous though.. I miss having a Gen 2 <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 97 SR with blown motor [Re: 87Montero] #926180 01/16/09 05:08 PM
V
vr4 Offline
im pretty sure 97 is a 3.5 sohc.
those can be had for a dime a dozen....especially if it uses the non-crossover block. i have heads and a bare block sitting in my garage from a 3.5 sohc
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: 97 SR with blown motor [Re: vr4] #926181 01/16/09 06:19 PM
Mad_Scientist Offline
Spot on <img src="/forums/images/graemlins/kewl.gif" alt="" />
Heads? Hmmm
Re: 97 SR with blown motor [Re: Mad_Scientist] #926182 01/17/09 02:11 PM
dolomiti Offline OP
Thanks for all the help. As it stands, the guy doesn't want to sell for less than $2500. It is in really nice cosmetic condition (Interior looks new) but I told him to call me when he decides to sell for $1000.
Re: 97 SR with blown motor [Re: dolomiti] #926183 01/19/09 05:31 PM
V
vr4 Offline
i picked up my 95 SR with a blown engine for 301.
ive seen them on CL for 700-1100 a few times too.
91 MR2 turbo
Re: 97 SR with blown motor [Re: vr4] #926184 01/19/09 08:22 PM
bretwalda Offline
FWIW there is a 92 SR with blown engine on the Milwaukee Craigslist for $1K OBO.
concreteprinter.com
Re: 97 SR with blown motor [Re: bretwalda] #926185 01/19/09 10:21 PM
Houston Offline
Damn, I could ALMOST afford to buy it and trailer it back to Chicago for parts! Hey Bretwalda, good to hear from you.
Houston
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6318 MB (Peak: 0.7359 MB) Data Comp: Off Server Time: 2026-06-07 07:05:52 UTC
