rocker arms
#926251
01/17/09 03:32 AM
hi all new here quick question? i recently had my timing belt cam belt water pump done since then very smokey and gutless now have broken rocker arm can this be attributed to recent work done as above?
swb 2.5 tdi
swb 2.5tdi 33" muds-50mm body lift-40mm OME rear coils-2.5"exhuast-ball joint flip-snorkel-unifilter air cleaner-added bonnet scoop for intercooler-ARB rear locker
Re: rocker arms
[Re: topcat]
#926252
01/17/09 05:55 AM
yes, timing was set wrong and your piston hit your valves...very common with these engines to break rocker arms when timing is out and piston/valve make contact.
Re: rocker arms
[Re: torquemonster]
#926253
01/19/09 09:39 AM
Very true I have seen it on a 4d55 were all the rockers were broken because of out of time belt.
89 2 dr turbo diesel 89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5956 MB (Peak: 0.6487 MB) Data Comp: Off Server Time: 2026-06-17 11:42:27 UTCValid HTML 5 and Valid CSS
