trouble starting
#926407
01/18/09 03:13 PM
Just put a engine in my 91' trooper. (2.8 4x4 auto) Having trouble starting it everything is hooked up imk pretty sure it will start but i have to pump the gas. Could it b bad gas, or a vaccum hose? It kinda smokes out the Throttle Body. Help!!
Re: trouble starting
[Re: riding4him]
#926408
01/18/09 07:43 PM
Maybe the timing is way off?
Steve Carlson - 95 Trooper LS expo rig Serenity now!
[Re: BigSwede]
#926409
01/19/09 12:04 AM
I did remove the distributor cap could that be it? Cause i had the motor in another trooper right before i put it in my nicer trooper, and i drove it around and was fine. I didnt tear into the motor at all. If it is the distributor how is the best was to check the timing? Thanks for your help!
[Re: riding4him]
#926410
01/19/09 03:12 PM
The dist cap should go on and off without affecting timing...but if you twisted the distributor itself during install that would affect timing.
The only way I know of to check timing is the old-fashioned timing light method. Check a shop manual for the procedure.
Seems worth checking, the "smoke" from the throttle body says to me the timing could be off.
[Re: BigSwede]
#926411
01/19/09 03:24 PM
That sounds like what it might be. Thanks alot for all you help i realy do appreciate it!! Have a good day and God Bless!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6040 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-06-07 05:47:03 UTCValid HTML 5 and Valid CSS
