oil pressure gauge #926733 01/20/09 12:02 PM
hartbeat Offline OP
Hi new to your forum just purchased 96 jeep cherokee 4L auto
oil pressure gauge reads of the dial oil level spot on any ideas
Allan
Re: oil pressure gauge [Re: hartbeat] #926734 01/20/09 02:28 PM
rixcj Offline
What?! <img src="/forums/images/graemlins/drunk.gif" alt="" />
'79 CJ5,401,t-18/d20,dana30/amc20(Mosers),GM HEI, Edelbrock Performer intake,Holley 600, ps/pb, 'glass tub/1pc. tilt nose, 33x12.50x15 BFG T/A's. Lots more to be done...
Re: oil pressure gauge [Re: rixcj] #926735 01/20/09 04:35 PM
jstritec Offline
So is it reading of(f) the dial too high or no reading at all?
80 CJ-7.
It runs
Re: oil pressure gauge [Re: hartbeat] #926736 01/20/09 05:34 PM
4x4Wire Offline
Replace the sensor.
Simple procedure that does require a special socket to accommodate the connector on the end.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: oil pressure gauge [Re: hartbeat] #926737 01/21/09 12:41 AM
Bigbird79 Offline
check and make sure the wire is connected to the sensor.
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: oil pressure gauge [Re: Bigbird79] #926738 01/21/09 12:54 PM
hartbeat Offline OP
Hi thanks for the info where is the pressure switch located
iam in the UK so the vehicle is right hand drive if that helps
Allan
Re: oil pressure gauge [Re: hartbeat] #926739 01/21/09 02:58 PM
Bigbird79 Offline
I donÆt know where the sensor is located for sure; I haven't had any issues with any sensors on my XJ. But, it should be a sensor (I would guess cylindrical in shape) that threads into the side of the block and I would guess it has one wire connected to it.
I suggest checking the connection first because itÆs a simple check, and a buddy of my had a Pontiac of some flavor, and the Oil pressure gauge would peg out to max as soon as he turned the key on, engine not even running, and never moved off the peg until power was turned off. The engine was quiet, and the oil level was just fine, we assumed bad sensor too. A couple beers, and the 2 of us poking around under the car and under the hood, for about 20 minutes and we found the connector had come loose, and just wasnÆt making a connection any longer. We clipped the plug back on the sensor and the oil gauge read perfect. Go figure, things work better when hooked up.
It could be a bad sensor too, but you might as well check whatÆs easy to check before you remove any parts, and spend any money. Just my 2 cents.
Sean
Re: oil pressure gauge [Re: Bigbird79] #926740 01/21/09 03:22 PM
BigJim Offline
Should be on your drivers side towards the back of the engine, above the oil filter.. ON THE BLOCK and not the head.. Most look like an old snuff can... small and originally gold in color.
Re: oil pressure gauge [Re: BigJim] #926741 01/22/09 01:31 AM
cuervo25 Offline
Nope BJ on the newer models they are on the passenger side near the oil filter. Mine was silver in color instead of gold,but perhaps it was changed. however it is towards the back of the engine block and low,and as I said near the oil filter.
Re: oil pressure gauge [Re: cuervo25] #926742 01/22/09 03:24 AM
BigJim Offline
Cuervo... I said "on HIS drivers side".. He drives from the wrong side of the Jeep.. Is what I was thinking.. I must have confused his post with another one. And, yes I know zackly where the darn thing is. Might be having a senior moment with the wrong side steering.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-09 21:50:42 UTC
