2.6 bogs/surges at WOT? #927152 01/23/09 02:19 AM
Jamez Offline OP
So I've put a few miles on this '88 and it will rev fine in N past 4K without much fuss. On the highway at 60+ if I give it more gas to speed up or take on a hill, it will bog down to maybe 2K and I have to almost completely let off to regain any kind of power. Sometimes it will surge instead and if it weren't for the bogging would probably have plenty of umph to conquer highway speeds. Where should I start?
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: 2.6 bogs/surges at WOT? [Re: Jamez] #927153 01/23/09 03:28 AM
There is an FSM for the feedback carb in my collection. Can't help much more than that. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 2.6 bogs/surges at WOT? [Re: MontyMcV] #927154 01/23/09 04:20 AM
mxmikie Offline
check your fuel lines for cracks and check your oil for gas
Re: 2.6 bogs/surges at WOT? [Re: mxmikie] #927155 01/23/09 04:38 AM
My bet is fuel pump delivery. either filter or sock in tank on pickup or pump, probably not the last one. Or the float level is set too low.
Re: 2.6 bogs/surges at WOT? [Re: fasteddy] #927156 01/23/09 05:56 AM
don Offline
My guess is carb and vacuum collapse, but not sure where.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: 2.6 bogs/surges at WOT? [Re: don] #927157 01/23/09 05:18 PM
Jamez Offline OP
So looks like fuel delivery, somewhere between the rubber lines in the engine bay and the carb? Maybe a vac issue as in the lines or secondary?
Weber 32/36
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6121 MB (Peak: 0.6815 MB) Data Comp: Off Server Time: 2026-05-29 22:18:37 UTC
