E-Locker in 2nd Gen Runner? #927231 01/23/09 08:33 PM
TRDSR5 Offline OP
I get a billion search results but I think the answer is yes. I keep chewing thru rear pinion seals on the 93 V6 Runner, I'm not sure front bearing feels right when I snug up pinion nut but I've never done diff work. since it might be time for a new one I'd like an e-locker if it can be done.
Down time is crucial so the more plug-n-play the better. Thanks
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
Re: E-Locker in 2nd Gen Runner? [Re: TRDSR5] #927232 01/23/09 10:24 PM
G
Greg_Canada Offline
You can do it but you need to do something with the harness and get a new gasket and studs, and such, search the tech section for e-locker retrofit.
Inchworm makes a nice harness, ORS made one as well.
You will need to relocate 2 studs, so drilling/tapping and welding will need to be done. otherwise it bolts right in.
89 4Runner
Re: E-Locker in 2nd Gen Runner? [Re: TRDSR5] #927233 01/24/09 02:56 AM
Adam F Offline
The info you need is in our Toyota tech section on the main page
http://www.4x4wire.com/index.php?op...p;catid=68:toyota-tech&Itemid=53
If you get all your parts together, you can get it done in a days time. You can do it with the axle in the truck. Just clean it out really well.
97 4R, stock, daily driver
Re: E-Locker in 2nd Gen Runner? [Re: Adam F] #927234 01/30/09 04:42 AM
Runner-Man Offline
Yep. I put mine in my '89 Runner without taking the axle out, or any welding (have to be very careful when drilling and tapping.) Mine took a weekend, but I took my time and went slow (also known as 'really afraid I was going to screw it up'.) I cleaned the axle housing really well and still changed the fluid at 50 miles and 500 miles, just in case.
You can also build your own controller and pre-wire it before taking the truck out of service, like I did.
Re: E-Locker in 2nd Gen Runner? [Re: Adam F] #927235 02/05/09 04:36 AM
TRDSR5 Offline OP
Thanks Adam (and others). I stopped at Trails West and may end up going with the Tru-Trac since I have to pull it and replace gears anyway. I'll be in Cinci this weekend (sadly for a funeral), I'll throw another saeal in the diff and hope she makes it down and back
Re: E-Locker in 2nd Gen Runner? [Re: TRDSR5] #927236 02/05/09 10:45 AM
Adam F Offline
Supposed to get up into the 50's this weekend. Much better than 1 degree it is this morning. <img src="/forums/images/graemlins/frown.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6120 MB (Peak: 0.6991 MB) Data Comp: Off Server Time: 2026-07-09 17:41:21 UTC
