spring sagging #927292 01/24/09 03:55 AM
WunBigTacoma Offline OP
i was told 98-04 rear leafs wont fit my 95.5 tacoma 4x4,any suggestions dr side sagging on mine i have add a leafs would it help or would it still sagg? thax matt
Matt weaver
95,5 xtra-cab 5 spd 3.4
3.5 fabtech,w/diff drop 35x12.50,removed 3in body now running 285-75x16 on factorys,
hella lights,gauge pod,and gauges
tb spacer,intake k%n filter,flowmaster
Re: spring sagging [Re: WunBigTacoma] #927293 01/25/09 05:22 PM
humanoid Offline
Springs from a 98-04 will not fit because they are a tad longer than springs from 95.5-97. You can get some aftermarket ones from wheelersoffroad.com or Downey Offroad. AALs will help stop the sagging, but I would just get replacement ones.
Re: spring sagging [Re: humanoid] #927294 01/30/09 04:08 AM
could i not just replace them both with leaf springs off a newer one?
Matt weaver
Re: spring sagging [Re: WunBigTacoma] #927295 01/30/09 08:44 AM
humanoid Offline
Sure, but they will just end up sagging again pretty soon, unless you find some with some very low mileage.
Re: spring sagging [Re: humanoid] #927296 02/11/09 08:09 PM
my buddy has a 02 2wd tacoma wrecked,will those springs work or will they be 2 weck for my 4wd tacoma? thax matt
Matt weaver
Re: spring sagging [Re: WunBigTacoma] #927297 02/12/09 08:30 AM
humanoid Offline
Matt, like I stated earlier, 98-04 springs will not fit 95.5-97 trucks, springs from the earlier generation are slightly shorter than the ones from the later generation. So NO, they will not fit.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6086 MB (Peak: 0.6778 MB) Data Comp: Off Server Time: 2026-06-17 13:25:26 UTC
