battery trouble #927332 01/24/09 07:24 AM
riding4him Offline OP
I have a 2.8 V6 trooper 91' the battery went dead so i charged it and even put it in my other car for a day of driving to make sure it was charged. It ran awesome but when i put it in the trooper it wont even crank it over, The lights are bright it has power to everything. Could it be my starter? I dont know because the starter worked good before the battery went dead!! Any suggestions will greatly be appreciated! <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: battery trouble [Re: riding4him] #927333 01/24/09 04:54 PM
mlclark Offline
Isuzu Moderator
Starter, battery cables, fuses or seized engine. There is a lot of reasons a vehicle won't turn over. Start looking.
Cables and starter are a good place to start. A bad battery will wreck havoc on a starter. Make sure to check both the positive and negative cables. If they look corroded or even if they are original, it is probably time to replace them.
Michael
Re: battery trouble [Re: mlclark] #927334 01/24/09 06:24 PM
Thanks for the info! I sayed that the engine wont crank but it will just really slow. The starter did make kind of a zinging sound a couple of times when i tried to start it also.
Re: battery trouble [Re: riding4him] #927335 01/25/09 12:01 AM
mlclark Offline
Isuzu Moderator
The zing is the bendix coming off the flywheel.
For whatever reason, your starter is not getting enough juice. This can be a battery problem, a cable problem or a starter problem.
I would get the battery tested. It is quick and easy. Charging and running is one thing, but you want to know if it can a) hold a charge and b) operate at a load. Then I would start looking at the starter or the cables.
Have you tried jump starting it?
Michael
Re: battery trouble [Re: mlclark] #927336 01/25/09 09:42 PM
I had the battery checked they said it is good. I have also tried jumping it but still barely cranks. I cranks like it dont have enough juice to the battery. I guess it has to be in the cables some were. It is just weird cause it cranked fine until i left the key on one day and drained the battery.
Re: battery trouble [Re: riding4him] #927337 01/26/09 01:18 AM
4x4Wire Offline
Was it tested under a load???
IMHO, the battery testing equipment in most shops is not sufficient to really tell if a battery is good.
I fought with Sears on a battery they claimed was good on their tester. I had them use another tester which showed the battery as bad.
If you drained the battery, it could take a charge but it may not have enough capacity to fire the engine.
Also, WRT cables, make sure you have a good ground connection between the negative post, car body and engine.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: battery trouble [Re: 4x4Wire] #927338 01/27/09 02:37 AM
I had the starter tested it was good! I havent had the battery tested under a load yet but i will. It starts my wifes honda accord just fine, but i guess that v6 has to have more juice maybe.
Re: battery trouble [Re: riding4him] #927339 01/27/09 02:34 PM
mlclark Offline
Isuzu Moderator
Cables and starter could also be creating a much greater draw than your Honda.
m
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6239 MB (Peak: 0.7067 MB) Data Comp: Off Server Time: 2026-06-10 07:26:36 UTC
