Rotor replacement - Hub STUCK to rotor?! #927368 01/24/09 04:47 PM
Liquid_force Offline OP
All six hub-rotor bolts are out. Rotor is off truck, ABS ring is off rotor. It's just rotor/hub and the hub will NOT come off. I've beat it a few times with the deadblow - no luck. What am I missing?
Dec '07 purchase -- '99 Sport LTD 3.5L SOHC - 139k, now 188k
'95 Montero LS 206k+ (traded)
New DD - '99 Taurus SHO 95k - V8's are fun <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Rotor replacement - Hub STUCK to rotor?! [Re: Liquid_force] #927369 01/24/09 05:03 PM
Give it a dose of Blaster and let it sit. Then beat some more. Repeat until seperated.
Note: A mini-sledge is better than a dead blow for this one.
Re: Rotor replacement - Hub STUCK to rotor?! [Re: Liquid_force] #927370 01/24/09 05:12 PM
no kiddin'?
I thought surely there was another fastener somewhere I just wasnt seeing. I PB'd it once, and I need to make a tool run so I'll let it sit and hope for the best.
Re: Rotor replacement - Hub STUCK to rotor?! [Re: Liquid_force] #927371 01/24/09 05:28 PM
for future referene...
I ended up using a std sized straight edge screwdriver as as wedge driven between each wheel stud and the rotor, then a larger screwdriver, then I was able to use my 18" prybar to finally seperate them. Liberal use of PB blaster along the way as well.
Not fun. I was really surprised it took that much force.
Re: Rotor replacement - Hub STUCK to rotor?! [Re: Liquid_force] #927372 01/24/09 05:36 PM
I always put new rotors on. When I last did mine, I hit them hard enough to bang them up, but didn't care of course.
The other route would be to use a press.
Re: Rotor replacement - Hub STUCK to rotor?! [Re: MontyMcV] #927373 01/24/09 07:14 PM
CapnCrunch Offline
I always have several short sections of 2x4 and a small sledge on hand for that purpose (and some PB Blaster). Works like a charm.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Rotor replacement - Hub STUCK to rotor?! [Re: MontyMcV] #927374 01/24/09 07:31 PM
ForcedAir_Montero Offline
Yep- you really need that sharp "resonance" of the metal-to-metal for this one. A dead blow is just that... dead.
Glad you got it off!
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Rotor replacement - Hub STUCK to rotor?! [Re: ForcedAir_Montero] #927375 01/25/09 12:00 AM
Wheel lugs in or out?
two or 4 pieces of 2x4 for disc supports and a 4lb minisledge and lots of mouse milk, and antiseize the new one...
Re: Rotor replacement - Hub STUCK to rotor?! [Re: fasteddy] #927376 01/25/09 02:28 AM
Hans_GZP Offline
I wish I put new rotors on (nobody had them instock) when I did mine. I do have to take my hubs back apart to replace the ABS rings that broke in 3 pieces while taking them off, so I might just order up the rotors this time. I turned them down, but I think they are getting kinda thin for a truck this size.
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
95 Mitsu 3000GT, carbon black, for sale
95 Mitsu 3000GT, white, for sale
92 Mitsu 3000GT VR4, silver, for sale
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6277 MB (Peak: 0.7307 MB) Data Comp: Off Server Time: 2026-06-23 11:14:43 UTC
