valve stem seals? replace or not? #928340 01/30/09 11:23 AM
menotthat Offline OP
just had the head machined flat because of overheating and blown head gasket. before i put the head back on, should i replace the valve stem seals? has anyone had to replace these seals before? how often are they needing replacing? or will i get many more years before they will worry me?
i am eager to put my car back together, but if they'll need to be replaced soon, then it would be a wise move to do it now.
the other concern of mine is that i have just had it all checked, but what if for some reason it doesnt go back together properly and there is a leak or something. Will it matter if the valve gets rotated.
thanks guys
97 sportage, mostly stock apart from king springs front and rear, monroe shocks, k&n filter, pioneer mp3 cd, rampage 2x 10"subs and rampage amp.
Re: valve stem seals? replace or not? [Re: menotthat] #928341 01/30/09 03:10 PM
DamKia Offline
Kia Moderator
By "rotated" do you mean placed in a different valve port in the head? If this is the case then technicaly yes they should be re-lapped into their "new home" to make sure they seal properly against the valve seat.
The best idea is to make a plywood board with (in our case) 16 holes set out as the head is laid out, and as the valves are removed they are placed into the corresponding hole in the ply. Total cost $0.50 and 5 mins.
Valves will normally rotate in the head and in fact the rockers are usually ground with a bit of an angle on them where they strike the valve. This prevents undue wear on one part of the valve.
Re: valve stem seals? replace or not? [Re: DamKia] #928342 01/30/09 04:05 PM
Everet Offline
If you got it hot enough to warp the head, then by all means change the valve stem seals.
As long as you have the head torn down, have the valves done. Then you will know that everything is correct.
Re: valve stem seals? replace or not? [Re: Everet] #928343 01/30/09 10:04 PM
fokion Offline
and also look if the valves are loose in their "tube" ( remind you I an Greek!!!)...
That will eventualy give you smoke of oil at the exaust...
Basicaly if you are planing to keep the car, fix aw many things possible..
Re: valve stem seals? replace or not? [Re: menotthat] #928344 01/30/09 10:56 PM
DennisThompson Offline
Have the machine shop check you stems and and seals, I didn't have mine done but now that I have to rebuild the engine I will have the head compleatly gone through. Have to find a new machine shop though, the one I was using burnt to the ground the other day. See, my problems are not so bad!
Dennis
Re: valve stem seals? replace or not? [Re: DamKia] #928345 01/31/09 02:08 AM
i plan to put it all back in same holes. but thanks for clearing up that it doesnt matter if i spin the valve, only that i must go back in the same valve hole.
so i might as well do it now. may save me a hassle and money later.
cheers guys
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6114 MB (Peak: 0.6818 MB) Data Comp: Off Server Time: 2026-07-15 18:36:34 UTC
