Dashboard Light #928606 01/31/09 03:48 AM
Superman Offline OP
Some of my lights are dimming out, especially on the side where is shows the gas gauge. Also, the dial that switches the vents is not lit like the fan dial and the temperature dial.
Can I change this by myself?
Thank You
Clark
Tacoma PreRunner Double Cab V6 Automatic
3.4-liter V6 TRD
Re: Dashboard Light [Re: Superman] #928607 01/31/09 09:19 AM
humanoid Offline
Re: Dashboard Light [Re: humanoid] #928608 04/20/09 08:43 AM
Superman Offline OP
Those are good sites and I am finally getting around to changing it. Is it possible to replace the Map Light (Personal Light)? I am trying to get the bulb size but could not find it on google. I also would like to know how to replace or take apart the cover for the bulbs for the Map Light.
Clark
3.4-liter V6 TRD
Re: Dashboard Light [Re: humanoid] #928609 04/21/09 03:45 PM
RichinROA Offline
EDIT---n/m. Just problem with browser at work. <img src="/forums/images/graemlins/kewl.gif" alt="" />
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: Dashboard Light [Re: Superman] #928610 04/22/09 07:06 AM
kewlynx Offline
Call NAPA or the dealer and get the part number for the map light bulb. If you still have the owner's manual, the swap should be in there, as well as a part number.
**ubi apis- ibi salus**
Re: Dashboard Light [Re: humanoid] #928611 05/03/09 10:20 AM
Superman Offline OP
If you have a Tacoma Prerunner 2003, the instruction is off a bit. It does not use #74 bulbs but have to special order from the dealership. It cost about $15 each and requires 3 instead of 2. It requires 4 #194 bulbs instead of 2.
Take apart is almost identical.
I bought the #194 from SuperBrightLED and it sell great blue. Don't bother changing the dome light. It is not as bright.
You can change the instrument light color but cannot change the AC/FAN/Heat controls light color. My come with orange and it is already tinted like that.
Clark
3.4-liter V6 TRD
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6112 MB (Peak: 0.6809 MB) Data Comp: Off Server Time: 2026-06-21 01:45:14 UTC
