86 trooper glow plugs #928690 01/31/09 11:41 PM
1
123harlan Offline OP
began having trouble starting recently,thought it might be fuel shutoff solenoid on pump as it was intermentet problem. now i have discovered that using the block heater helps, so i checked glow plugs and all are bad. could the qos controller have caused this or is it common for all plugs to go at the same time. thanks dan
Re: 86 trooper glow plugs [Re: 123harlan] #928691 02/01/09 04:24 PM
JLEMOND Offline
not at all uncommon
WHAT USUALLY HAPPENS , WHEN ONE GLOW PLUG GOES OUT, THE AVAILABLE VOLTAGE IN THE CIRCUIT FOR THE GLOW PLUGS WILL RISE , APPLYING MORE VOLTAGE TO THE REMAINING PLUGS , AND THEY WILL OVER HEAT SINCE THE CURRENT GOES UP, THEN THE NEXT WEEKEST ONE IN LINE WILL GO OUT AND SO ON UNTILL THEY ARE ALL DEAD , USUALLY IN ABOUT 45 SECONDS OF HEAT TIME , THOSE GLOW PLUGS CAN DRAW AS MUCH AS 40 AMPS WHEN HEATINGS , YOU ARE NEVER SUPPOSSED TO REPLACE ONE INDIVIDUAL PLUG AT A TIME ,ALL WAYS REPLACE ALL 4 , AND CLEAN THE HOLE IN THE HEAD OF ALL CARBON BUILDUP WHERE THE TIP OF THE PLUG GOES UP IN THE HEAD , THIS WILL KEEP THE PLUGS FROM OVERHEATING AND ALLSO MAKE THE ENG START FASTER ALLSO BE CERTAIN THAT THE GLOW PLUGS ARE THE CORRECT TYPE , JERRY
Re: 86 trooper glow plugs [Re: JLEMOND] #928692 02/01/09 04:44 PM
1
thanks for the info jerry,I did not want to fry a set of glow plugs if i had another problem. thanks again dan
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5922 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-06-07 00:48:41 UTC
