Rear Disc Part numbers
#929374
02/04/09 01:08 AM
I have a 91 LWB diesel Pajero with rear disks that is in the shop for a seized rear caliper. I need the NAPA or raybestos part #'s for the rear disks, calipers, and pads(ASAP). I searched the archives and other posts but I couldn't find the numbers. I saw that the calipers seize often, is there anything that I can tell the tech to do to minimize the reoccurance. Thanks
1991 LWB Exceed Q-V44WG RPF 4D56/V4AW2/5285 2005 Ford Excursion 6.0L Diesel
Re: Rear Disc Part numbers
[Re: Coastal_Dreamz]
#929375
02/04/09 08:07 AM
Is this 91 Pajero you have the same as our 92 Montero's? i.e. the first of the more rounded design? If so, I'll need someones' VIN for a rig with that axle and I can look it up using caps.
[Re: off-roader]
#929376
02/04/09 09:44 AM
you can source the rear brake parts for a 1992 Mitsubishi Montero, most all parts stores will have it in there system. even up here in Canada. the local partsource had rear pads in stock for me when I went looking.
[Re: torquemonster]
#929377
02/04/09 01:52 PM
Thanks for the info, the shop was pretty sure the discs were from the 92 Montero but there were no exact size specs on their book and if they were wrong, I just bought a set that I would not be able to use. Once again thanks for helping a newbee <img src="/forums/images/graemlins/kewl.gif" alt="" />.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6021 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-07 05:43:27 UTCValid HTML 5 and Valid CSS
