Page 3 of 3 1 2 3
Re: 4D56 Injectors [Re: CityYeti] #929483 02/17/09 10:45 PM
torquemonster Offline
well I've seen the truck numerous times before lol. but i would guess either they screwed up on the injector rebuild, bad fuel, or pump needs to be tuned.
Re: 4D56 Injectors [Re: torquemonster] #929484 02/18/09 03:01 AM
PHIL_ Offline
But this is the first time you've seen "Maurie's" truck, right?
So burning blue on startup, but nothing after its warmed up?
Re: 4D56 Injectors [Re: PHIL_] #929485 02/18/09 03:14 AM
haha true phil. yea its burning blue basically all the time. and A LOT of black under hard acceleration. more than mine with no cat or muffler and I thought mine smoked a lot.
Re: 4D56 Injectors [Re: torquemonster] #929486 02/18/09 04:29 AM
PHIL_ Offline
Maurie, what's the status of the EGR? Blanked, solenoids removed... both?
Re: 4D56 Injectors [Re: PHIL_] #929487 02/18/09 05:55 AM
CityYeti Offline OP
unhooked the line and plugged it, that's all. It's not idling blue when warm just smokes allot when I'm on the throttle. I might blank the EGR in the next week or so.
Was: 4D56 Injectors, Updated: 4m40 injectors [Re: CityYeti] #929488 06/30/09 05:16 PM
PHIL_ Offline
Just an update. Mostly onboard with this topic, though for 4m40 injectors...
I have been having fuel consumption issues, lacking power and a little more smoke than I did at first. I tried most of the common fixes, but little difference. This culminated in a camping trip where I pulled my little trailer, and the truck really struggled. Add to this my oil level bizarrely increased... so... I pulled the injectors the other day and had them tested at the shop Maurie referenced above. All the nozzles are burnt, and two injectors are stuck open and dumping fuel. Unfortunately I'm leaving for holidays in a few days, and so they're ordering the parts, and I'll yank them again when I get back, and have them rebuilt. I'll report back on the results. I'm imagining a dramatic difference.
Just fyi, my truck now has just shy of 100k kms. If your mpg is going down, or you're lacking power, this may be something to check.
Re: Was: 4D56 Injectors, [Re: PHIL_] #929489 06/30/09 09:50 PM
supplespence Offline
I'm not sure if anyone else has seen this, but it looks like Hiflow has started making injectors for the 4d56 and has been makin them for the 4m40 as well. I've been meaning to give them a call to check out the price If it's reasonable, instead of cleaning out the injectors, it would be nice to have brand new ones...
Here is the link http://www.hiflo.com.au/fuel_injectors_list.cfm?vm=Mitsubishi
any thoughts?
1991 LWB Pa 'the PJ' jero Exceed
Re: Was: 4D56 Injectors, [Re: supplespence] #929490 07/02/09 09:37 PM
PartyTruck Offline
Once everything was apart and the injectors where out I plugged up any holes, locked up the truck and opened a Miller (you may choose a beer of your liking).
If I could only have a Miller I'd never do my injectors. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Was: 4D56 Injectors, [Re: PartyTruck] #929491 07/11/09 05:46 PM
PHIL_ Offline
Got back from holidays, hauled out the injectors (again), had them rebuilt, got new washers/gaskets, and reinstalled them. I still have the 31s on, but it overall seems smoother in the few kms I've put on it since. The big test will be tomorrow, when I pull the trailer again. Last tank of fuel (through the rockies, towing, mind you) averaged 15.5L per 100 kilometers. Abysmal! If I can get back to 10L/100km again, I should quickly recoup my investment in the injectors. And some extra power will definitely be a bonus.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6389 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-06-17 11:43:55 UTC
