Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: bombardj1] #929575 03/04/09 04:15 AM
kellbell77 Offline OP
i am still stumped! ok today it made a lite whistling! Stupid KIA! belts are fine! i am beginning to think its the fan in front. Heres the deal. Tonite, i was behing a semi and it made a horrible noise, so i passed it, it went to a slight whistling noise, and after i passed, the noise went away. I am so confused! Why is it just my KIA????
2001 Tan Kia Sportage, has a K&N air filter, Warn Hubs but there's nothing really special about it, but my 7 year old loves my KIA cuz she sits up high!
Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: kellbell77] #929576 03/04/09 11:49 AM
harvey Offline
I had a ticking noise on my 2001 kia, turned out to be the egr valve only happed on accelaration,loose timing belt changed the belt and it went
Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: harvey] #929577 03/04/09 05:08 PM
bombardj1 Offline
harvey, 2001 USA sportage don't use a egr, 1995 did.
Kelly, my fan makes noise and it's new I bought it a auto zone, so don't buy thier's if you replace yours, I only replaced it because the bi-metal spring broke and it over heated. So I just live with it. Sportages can be tempermantal at times. the fan I am talking about is the radator fan not the a/c fan in the front of the rad. if others post Idea's it might help me think of things also.
John
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: bombardj1] #929578 03/04/09 05:38 PM
Everet Offline
Ticking noise: could be collapsed hyd. lifter. or one that is leaking down.
Squealing noise: possibly timing belt idler roller or tensioner bearings. Think I have one going out on mine.
Power steering pumps can make bad noises if they are going out too.
Just a thought and let us know what you find.
Everet
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: Everet] #929579 03/04/09 05:40 PM
k120189 Offline
i had a ticking noise...i think my lifters needed adjusting...i'll know when take the head off cause my timing belt went on mine and i might have bent a valve...not fun
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: Everet] #929580 03/05/09 12:07 AM
bombardj1 Offline
Everet, how hard is it to replace the hyd lash adjuster on top of the valves ?
Re: Squealing noise/ticking noise on 01 sportage 4wd [Re: bombardj1] #929581 03/05/09 06:58 AM
Everet Offline
Haven't been there. Haven't read the manual on it.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6242 MB (Peak: 0.7144 MB) Data Comp: Off Server Time: 2026-06-17 04:20:18 UTC
