Cold Start Valve #929645 02/05/09 03:17 PM
JD9996 Offline OP
The cold start valve is spraying when the key is in the start position. The engine cranks but as soon as you let go of the key it cuts off after about 4 or 5 times it will finally crank. The engine does not run good for about a minute. Does it have a timer switch on the cold start valve for it to keep spraying when you let go of the key?
Thanks,
David
Re: Cold Start Valve [Re: JD9996] #929646 02/05/09 04:50 PM
4Crawler Offline
Cold start injector timer switch is located under the throttle body, one of the two forward facing devices with wiring connected to them. The FSM has the full testing procedures, mainly resistance vs. temperature checks.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5904 MB (Peak: 0.6383 MB) Data Comp: Off Server Time: 2026-06-10 06:33:17 UTC
