Page 1 of 3 1 2 3
FJ Cruiser 17" Steels on Gen2? #929667 02/05/09 07:36 PM
DavidG Offline OP
Hello all,
I know the center bore diameter may be just a hair too small (that can be addressed), but I'm curious if the dimensions would work on a Gen2. I love plain steel wheels and have never been a fan of the polished factory 15x7 alloys my rig has. It appears the OEM FJC steel wheel is 17x7.5 / +15mm offset / 4.5" backspacing. Anyone running an aftermarket 17" on your Gen2? I have access to a set and since I'm thinking about buying a new set of tires I thought I may try this route.
Thoughts?
-David
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: FJ Cruiser 17" Steels on Gen2? [Re: DavidG] #929668 02/05/09 08:11 PM
hazy_daze Offline
Judging the dimensions, you should be fine. At least for a GenI it would be. Will they let you test fit one?
Re: FJ Cruiser 17" Steels on Gen2? [Re: hazy_daze] #929669 02/06/09 03:51 AM
DavidG Offline OP
I brought one home to take measurements. If it ever warms up here I will pull a tire off and see how close it would be to fitting.
1997 Montero SR
Re: FJ Cruiser 17" Steels on Gen2? [Re: DavidG] #929670 02/06/09 06:49 AM
I mounted up a Tacoma wheel on my Raider. I'd have used it except for the extra 0.5" inset of the wheel. Maybe there's more clearance room on the Gen II, but I liked the idea of a wider stance for my Raider. FWIW. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: FJ Cruiser 17" Steels on Gen2? [Re: rxinhed] #929671 02/06/09 04:18 PM
DavidG Offline OP
I took a quick look last night and the backspacing I measured is closer to 5", which I think will be too much. I will know for certain this weekend. Thanks for the input fellas!
1997 Montero SR
Re: FJ Cruiser 17" Steels on Gen2? [Re: DavidG] #929672 02/06/09 06:33 PM
Alex Kogan Offline
Forget the backspacing. Stock montero offset is +10 mm, changing it to +15 mm is just fine if you plan to stay with close to stock tire sizes 31-32" if more you might start having issues. Although it would still prob fit 33s fine. One disadvantage going to 17" wheels tires will cost noticeably more. Then there is that center bore issue.
08 PowerWagon (stock!)
Re: FJ Cruiser 17" Steels on Gen2? [Re: Alex Kogan] #929673 03/23/09 05:15 PM
DavidG Offline OP
Okay, need more feedback. Here's what I found...
Stock 15x7 wheel on my 1997 SR has a bore of 108mm and approx. 4.50" backspacing from mounting surface to outside edge.
FJC 17x7.5 has a bore of 106mm and approx. 4-7/8" from mounting surface to outside edge.
The FJC wheel is 1/2" wider, but most of the width will be inboard. Has anyone had any experience running a wheel with 5" BS on a GenII? Any ideas if it will fit? I know it's only .5" but that can make a difference.
Thanks!
1997 Montero SR
Re: FJ Cruiser 17" Steels on Gen2? [Re: DavidG] #929674 03/23/09 05:26 PM
sparkem Offline
Do it.
Re: FJ Cruiser 17" Steels on Gen2? [Re: DavidG] #929675 03/23/09 05:37 PM
Thanks!
If the tire is made for exactly 106mm hub you will need to bore it out further which can be a pain.
BS fit will depend on the size tire you plan on using which you haven't said. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: FJ Cruiser 17" Steels on Gen2? [Re: off-roader] #929676 03/23/09 05:59 PM
DavidG Offline OP
LOL @ Sparky aka The Stig.
I'm planning on 255/75-17 BFG Muds. I know I will need to grind the center bore out, but that should not be a big deal. It is really close to fitting and would only need a little grinding.
1997 Montero SR
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6478 MB (Peak: 0.7685 MB) Data Comp: Off Server Time: 2026-06-07 06:57:50 UTC
