turbo? #929703 02/05/09 10:58 PM
F
fukthis Offline OP
i have a little isuzu pickup. it has no balls its a 2.6 lt gas motor. i am doing new exhaust in spring going 2 1/2 pipe and high flow cat and muffler. im hoping that will help me to do the speed limit up canyons and over the freeway passes. i have been looking at the idea of doing a turbo, has anyone herd of this? any ideas? im also thinking of doing a new cam just to get some more low end torque. it is 4 wheel drive and i do go off road alot, at least till i can get my blazer built. so i plan on doing a snorkle and a stack out the back, just becouse i find my self in the rivers and big boy mud puddles. i dont want to lift the indapendant, its a wast of my time, ill be doing the strait axle converson when i have time.. ill lift it then. any input would be much appreciated thanks kyle
Re: turbo? [Re: fukthis] #929704 02/05/09 11:03 PM
F
fukthis Offline OP
oh its 1990 ls space cab 5 speed manual. 31 inch mudds all stock other then. 2.6 fi 4cil
i have found a bunch of stuff on indapendant 4x but any other sites that you think would help me out, im more then open to.
Re: turbo? [Re: fukthis] #929705 02/06/09 01:48 AM
reran Offline
If ya can get your hands on a 2.0 turbo set up from an Impulse, it's almost a direct bolt in. I believe the only modification to the 2.6 would be to add an oil line from the other side of the engine. I'm sure someone on here can give you all the specifics of the install. HTH
94 Trooper S, 3.2 SOHC, Auto, Aisin's, OME 912's, TBC, Indy 4x HD TRE, Tokico shocks, AR Outlaw II's 16x8, Bridgestone Revo's 265/75x16
89 Trooper S, 2.6, auto, work in progress
Re: turbo? [Re: fukthis] #929706 02/06/09 01:50 AM
lttlbddy Offline
Turbo
Supercharger
Dan has a bunch of other mods documented on his site, look around.
Re: turbo? [Re: fukthis] #929707 02/06/09 01:54 AM
strawmyers Offline
Isuzu Moderator
any ideas?
My main idea is that, while you only have two posts, now is a good time to re-register with a new screen name that DOESN'T read like it was picked out by a 14 year old trying to impress his buddies. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
http://www.houlster.com/amigo/index.htm Has a lot of good info about mating a turbo to the 2.6.
I had the 260 regrind by Delta cams done to my stock cam and find it to be a worthwhile investment.
Sean Strawmyer
Re: turbo? [Re: strawmyers] #929708 03/19/09 06:30 PM
TrooperBeliever Offline
Maybe he IS a 14 year old trying to impress his buddies?! <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
If you need a local group for help and Ideas and to go wheeling with, check out http://zutah.com/
(Formerly known as Black-n-Blue)
86 Troop --- for Hiking, Mtn.Biking, Camping, Canoeing, and Wheeling too!
"...and remember, If women can't find you handsome,
they should at least find you handy!"
-Red Green
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6073 MB (Peak: 0.6784 MB) Data Comp: Off Server Time: 2026-05-29 22:18:57 UTC
