treadwright tires #929779 02/06/09 05:12 AM
jays2001 Offline OP
looking at picking up a set but was seeing witch tire the mtr tire or the otr i dont know witch is better or if anyone has used them we have a dealer 5 miles from our house so im going to look tommorow at them in person to see.
any opinions/experince with this would be greatly appreciated <img src="/forums/images/graemlins/patriot.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: treadwright tires [Re: jays2001] #929780 02/06/09 06:27 AM
Everet Offline
I'm running the OTR's. The M/T's and M/T ultras look pretty tough and probably would have ordered the ultra's if they were available. The OTR's are a little noisy but are wearing like iron.
The next set I get will be the ultra's.
Peterson's 4x4 magazine did an article on them and give them high marks. I don't think I will ever buy a new tire after having these. You cannot find a better value.
Keep us posted on your decision.
Re: treadwright tires [Re: Everet] #929781 02/06/09 05:45 PM
jays2001 Offline OP
thanks that was what i was thinking of going with im on my way now to see them ill let you know how they look. i couldnt decide what to do because a friend has a set of truxxus 33 s for cheap 200$ that have less than 5000miles on them when he rolled his pathfinder. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: treadwright tires [Re: jays2001] #929782 02/07/09 12:18 AM
logansportage Offline
33 by what? You might have a hard time fitting 33s under the Sportage unless they are only 9.50 wide even if you have Dave's 4" lift.
Re: treadwright tires [Re: logansportage] #929783 02/07/09 12:41 AM
jays2001 Offline OP
i think 12 0r 12.5 not sure looking at them sat so ill know more then. on the other hand my rims are a 15x8 and they are what i call deep dish or the back side of the rim is flat where it bolts up. <img src="/forums/images/graemlins/kewl.gif" alt="" /> that might help but not sure.
Re: treadwright tires [Re: jays2001] #929784 02/07/09 02:47 AM
DamKia Offline
Kia Moderator
The most important thing about the tires is their measured diameter. Anything more than about 32" is going to catch on the bodymount near the firewall on the chassis under moderate turning/full compression. No amount of lift will avoid this.
Having said that, most manufacturers are "optimistic" about their tire sizes, a "33" may in fact measure 31 inches when mounted.
12.5" wide may be an issue with clearance to the firewall near the "A" pillarduring turns. The last thing you want to do is to crush the "A" pillar with your BFH as this would seriously compromise the strength of the body, possibly leading to windscreen fractures, further spot-welded seam movements/seperations, and other assorted issues (door drops, squeaks/rattles as the body shakes itself to bits)
Lesson: Take a tape measure with you when buying tires
Re: treadwright tires [Re: DamKia] #929785 02/10/09 01:18 AM
If your wheels are 15 x 8 and have the flat side to the inside this pushes the wheels out a long way. When you turn you will have rubbing issues on the front end. You will also get lots of rubbing on the body on the rear end as you articulate the axle.
I've run 10.50" tires on the stock wheels that have the flat side on the outside and there is some rubbing on the inner fender well under full articulation. However, the tire was stuffed into the wheel well with very little to spare on the outside.
With a 33 x 12.50 tire, you'll want to setup your bump stops to keep the rear wheels from coming in contact with the body under articulation.
Re: treadwright tires [Re: logansportage] #929786 02/10/09 04:45 AM
jays2001 Offline OP
thanks i was thinking about that and the power isues of turning the 33s so i decided to go with the treadwright 31-10.50-15. <img src="/forums/images/graemlins/kewl.gif" alt="" /> the mtr ultras. they look sweet in person and the vender here in warsaw, il. can get them cheaper than i could ordering from the company they said 450$ to my door and the vendor said 440$ mounted and balanced <img src="/forums/images/graemlins/smile.gif" alt="" />
so i will have them next monday. <img src="/forums/images/graemlins/frown.gif" alt="" /> wanted sooner things are starting to get warm and ground is getting soft good time to play in the mud!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
thanks for all the feed back guys!! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: treadwright tires [Re: jays2001] #929787 02/11/09 07:45 AM
A
Adskia Offline
33inch tyres will fit........as i have 34/9.5r15 tyres on mine..... but its a massive job to get them to fit..... like a few have said...... the body mount at the rear of the front guard is the biggest headache......but with some body work they will fit......
THE POWER TO SUPRISE.
Re: treadwright tires [Re: Everet] #929788 02/11/09 07:46 AM
A
Adskia Offline
by the way guys ....... is there a website thatt these tyres are at would like to have a look at em....
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6408 MB (Peak: 0.7665 MB) Data Comp: Off Server Time: 2026-05-29 20:01:51 UTC
