Fuel Gauge Probalem #929808 02/06/09 07:06 AM
93montero_sr Offline OP
My fuel gauge cant decide on how much gas is in the tank. It will go from a 1/4 tank down to the E symbol when there is a 1/4 tank of gas in there. It sometimes does it when im stopped then after a mile or so will go back to where it should be. Is this a sighn my fuel pump is on its way out? Is it ground wire probalem? I did test my coolent for voltage and it read .11 volt on the meter instead of around 3-5 for being good. The .11 would indecate a lose or bad ground but i dont know if it pertains to what is happening to my fuel gauge.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: Fuel Gauge Problem [Re: 93montero_sr] #929809 02/06/09 07:42 AM
89montero Offline
It shouldn't have anything to do with the fuel pump.
I would check the connection at the sender. Pull back rear carpet and there's an access panel, directly under that is the fuel pump but to your left(drivers side) I think is access to the fuel sender(what tells the gauge how much gas there is).
1989 Montero 4dr V6 3.0l
Re: Fuel Gauge Problem [Re: 89montero] #929810 02/06/09 07:46 AM
Sorry i meant the float on the fuel pump.
Re: Fuel Gauge Problem [Re: 93montero_sr] #929811 02/06/09 07:50 AM
torquemonster Offline
I would almost put money on your sender being fubar'd. not a big deal, usually an easy fix and cheap fix. but I would check all the electrical connections from the sending unit to the gauge just to rule them out.
Re: Fuel Gauge Probalem [Re: 93montero_sr] #929812 02/06/09 04:56 PM
ghostraider Offline
i have seen this problem before on Many Many Vehicles.
You have a flat or worn spot on the Fuel Sender Rheostat.
this is a fairly common problem to fuel senders. Since most people tend to NOT fill their vehicles up fully; the sender operates in the lower half most of the time. This will create a worn spot.
It is imposible to repair it ( unless you are me ) and you will more than likely need a new or used sender for the vehicle.
It is doubtful that the gauge is bad as they tend to crap out completeley. I doubt the float is bad else it would act up at any fuel level.
Good luck!
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Fuel Gauge Probalem [Re: ghostraider] #929813 02/06/09 05:19 PM
How much are they and were can i get them?
Re: Fuel Gauge Probalem [Re: 93montero_sr] #929814 02/06/09 07:41 PM
jrowe Offline
I fixed mine as well. It's like soldering hair! I broke more wires than I had before I started. In the end, I was able to fix it.
Joe
Re: Fuel Gauge Probalem [Re: jrowe] #929815 02/06/09 10:02 PM
So its all one peice im finding out and the fuel pump aint cheap <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Fuel Gauge Probalem [Re: 93montero_sr] #929816 02/07/09 07:09 AM
ghostraider Offline
ok...here is the deal.
The sender portion is seperate from the actual fuel pump electronics in most cases. even though it comes as one unit.
The trick is to find a junkyard and pull The unit, then dissect it to remove the Rheostat. Small to large wire type cutters may be needed. It most times can be bent back and removed no problem.
Take care to examine the rheostat for flat spots too! Don't want a used part worse than the one you got.
as a last resort: fork over the cash for the unit!
My Raider gets to 1/4 and eventualy runs out of gas while still at 1/4 but that is because of the massive dents in fuel tank! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Fuel Gauge Probalem [Re: 93montero_sr] #929817 02/10/09 12:39 AM
MI_Mitsu Offline
May be relevant if you dont want to attempt a repair yourself and dont mind shipping to NY with a small wait!
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6384 MB (Peak: 0.7471 MB) Data Comp: Off Server Time: 2026-06-07 04:49:00 UTC
