Page 3 of 5 1 2 3 4 5
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: DRaider90] #929882 11/19/09 01:38 AM
What am I missing on tying down the rear suspension? I have yet to do that or the hard fuel lines but have done everything else. going to crawl under there tomorrow night to do the hard lines/c-channel mount, so I guess I will see why you have to do it but can"t think of a reason why that step is nescessary.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: Mudraider] #929883 11/19/09 02:24 AM
0778drz110 Offline
when you lift the body the suspension will move with it, so you would have to lift the body 4-5 inches maybe more just to get the body off the frame...
same idea when jacking up your truck to change a tire with a short jack <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: 0778drz110] #929884 11/19/09 02:37 AM
<img src="/forums/images/graemlins/shiner.gif" alt="" />Man, that was too obvious. I was looking for something on the body/frame that it was nescessary to do that. Sometimes you just miss the forest for all the trees. Or a Homer would say; "DOH". Wait, actually I know why I missed that, I haven't slept in a Holiday Inn express lately.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: Mudraider] #929885 11/19/09 02:37 AM
N
NickR Offline
It helps when it come to seperating the body from the suspension with out having to jack the body to much.
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage
SR Axle
LSD 3rd member
Early Gen 1 Bouncy seat
Early Gen 1 two piece rear bumper
2 sets of SWB Gen I rear seat-belts.
Set of Aisin Hubs.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: NickR] #929886 11/19/09 02:57 AM
Oyaji_Jon Offline
We just used a high lift and did one side at a time. We did have to lift it quite a bit to get enough separation to get the body blocks in.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: DRaider90] #929887 11/25/09 08:44 PM
sidecardog Offline
What about steering? I assumed that something needs to be modified/loosened/shifted, etc for the 2"BL.
What about on a LWB?
Hopefully I'll be finally doing my lift at Christmas
2002 Montego Limited, 3.5 V6, 90K, just purchased
1990 Montero LS, LWB, AUTO, 3.0 V6, 250K, 2" SL, 31" tires--SOLD
1959 Vespa VBA150 all original w/sidecar
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: sidecardog] #929888 11/25/09 08:54 PM
Nothing needed for my SWB. The steering shaft in the engine bay is like a slip-yoke and it just slides out the little that is needed for the extra reach.
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: MontyMcV] #929889 11/25/09 10:19 PM
sidecardog Offline
How long did the whole job take?
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: sidecardog] #929890 11/26/09 12:38 AM
DRaider90 Offline OP
A body lift will take the better part of an afternoon. Mark and Myself did it in about 6-8 hours. Its not complicated, it is just time consuming. Keep in mind all the stuff you have to do:
-If desired, use electrical tape to cover body mounts turning them from bright white to black.
-Drain Radiator, disconnecting the one hose, and taking off the fan shroud.
-Pull back carpet to access the 4 mounts located in the truck.
-Remove tail lights to access 2 of the 4 on the rear.
-Remove rear bumper to access the other 2 on the rear.
-Strap up rear suspension.
-Remove plate hiding fuel tank filler hose, disconnect.
-Remove bolts attached to fuel line bracket.
-Loosen all bolts, remove washers/nuts but leave bolts in.
-Make sure parking brake is off, and walk around re-checking all bolts.
-Slowly lift the vehicle on one side, install half the lift blocks/bolts.
-Let vehicle down and lift other side, install other half of lift blocks/bolts.
-Let vehicle down and go around and tighten down bolts.
-Install new radiator hose, re-install upper fan shroud.
-Re-attach fuel filler hose for gas tank, re-install plate.
-Install c-channel space for fuel line bracket.
-Bolt/snap carpet back inside vehicle.
-Put tail-lights back in.
-Cut semi-circles in diamond plate of bumper, then re-attach rear bumper.
-Release straps attached to the rear axle/suspension.
-Cut slit in front of t-case shifter to help with 4-Low notch.
-Re-fill Radiator and let vehicle come up to temperature and check for leaks.
-Test Drive Vehicle, and clean up old bolts etc.
It is a lot of stuff to do, and it helps having a 2nd person when tightening/loosening bolts considering it takes a ratchet on the top and bottom.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: 2" 4Crawler Body Lift Write up w/ Pictures [Re: sidecardog] #929891 11/27/09 01:53 PM
I had a total of probably 8 hours in it, which included cutting and drilling the UMWH for the lift blocks. Using other peoples on here, it was pretty simple. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I will get some pics today since I'm finally off and it is still light out.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6455 MB (Peak: 0.7712 MB) Data Comp: Off Server Time: 2026-06-20 21:43:15 UTC
